Old 11-15-2012, 08:47   #1 (permalink)
Member: 1070846
Thanks Meter: 4
c7-broken display
nokia c7 broken display after unlock key in the side..if you power on the mobile lcd display works fine but after it will lock and u will unlock sometimes it will be broken display..does anyone here have an idea?tnx
Old 11-15-2012, 09:17   #2 (permalink)
Sagitarious's Avatar
Member: 615730
Thanks Meter: 256
Brother as i understand when you phone on stand by mode then u unlock from side key then its not come clear its color fake and like broken display, so u need to be change the display (LCD).
Old 11-15-2012, 10:05   #3 (permalink)
Member: 1070846
Thanks Meter: 4
yah u are right brother but it is not LCD problem i think coz i already replace 3 LCD and its still thesame problem
Old 11-15-2012, 10:15   #4 (permalink)
Member: 615730
Thanks Meter: 256
Ok then change the complete first panel or strip, If same then u must reheat the D1400 Image processor. Post result.
The Following User Says Thank You to Sagitarious For This Useful Post:
Old 11-15-2012, 10:42   #5 (permalink)
Member: 1070846
Thanks Meter: 4
ok brother ill try to reheat that part,ill post the result later..
Old 11-15-2012, 10:50   #6 (permalink)
Member: 1070846
Thanks Meter: 4
bother thesame problem finish reheat i even move d ic a little,,do i need to replace this?
Old 11-15-2012, 14:34   #7 (permalink)
Member: 615730
Thanks Meter: 256
Brother before change it must check the lcd strip connector resold it if same then must change it - Post result..
Page generated in 0.14955 seconds with 8 queries
