07-19-2004, 18:42 | #2 (permalink) |
No Life Poster Join Date: Jun 2002 Location: CTSA Age: 46
Member: 12660 Status: Offline Thanks Meter: 7 | @ byte What software are you using ?? Can you read from the phone?? if so then try reflow cobba and try simlocks again regards D. Oh also check your cable. |
07-19-2004, 18:46 | #3 (permalink) |
Freak Poster Join Date: Nov 2003
Member: 44625 Status: Offline Thanks Meter: 36 | Also if ur cable is ok test the phone using eeprom tools. It may point u toward the fault. Could probably be a COBBA problem. Best to test with software before messing software. After flashing i use nokiatool ver1.8 to update FAID, write IMEI, clear SP locks and reset full factory settings. |
07-19-2004, 19:31 | #4 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Bandung - West Java, Indonesia Age: 43
Member: 71273 Status: Offline Thanks Meter: 14 | i think your phone condition now is SIM CARD NOT ACCEPTED isn't it ? does your software support to 3410 ??? what soft. did you use? try to use UFS-3 Regards |
07-19-2004, 21:57 | #5 (permalink) |
No Life Poster Join Date: Mar 2004 Location: romania Age: 42
Member: 57035 Status: Offline Thanks Meter: 70 | i have encountered this situation on 3310/3330/5110 ... first i thought it might be hardware problem ! tried eeprom tools and all kind of softwares on DEJAN MBUS CABLE ...! I have conected the phone to GRIFFIN ... and the wonder happened .. all phones solved ! TRY GRIFFIN ... it was , it is , and it will be THE BEST ! GOOD LUCK ! |
07-21-2004, 08:15 | #7 (permalink) |
Registered User Join Date: Sep 2003 Location: Palestine Age: 50
Member: 39208 Status: Offline Thanks Meter: 152 | Actualy i try griffin,knok,eeprom tools ..., but i did not success.. i change the cobba ic...but the same shall i change flash ic ...? or what shall i do ...? |
can i repair simlock data 5130c ? | u & me | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 02-13-2010 07:08 |
..::now u can find your simlock data ok or not by hwk::.. | msantar | HWK | 0 | 09-04-2009 07:48 |
wen i am updating my setool v0.914038_to_v0.914040 it can not update | neeraj1st | SETool2 | 2 | 10-17-2008 08:11 |
Can not store SP data on 8910 | vonguyenvu | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 04-14-2003 00:07 |
canīt update simlock data .Urgent plz | bonanza | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 20 | 09-17-2002 08:34 |
