Old 01-02-2010, 23:05   #1 (permalink)
Member: 608240
Thanks Meter: 162
change nokia model to another
3100b rh50 to 3100 rh19
flash it with rh19
write 3100 special pm file for speaker
ui settings.
Old 01-02-2010, 23:05   #2 (permalink)
Member: 608240
Thanks Meter: 162
3200b to 3200
only change filters and write good pm file.
Old 01-02-2010, 23:06   #3 (permalink)
Member: 608240
Thanks Meter: 162
3600 to 3650
change filters
flash the phone with 3650 flash files v3.16 ,write good pm and ui settings.
Old 01-02-2010, 23:06   #4 (permalink)
Member: 608240
Thanks Meter: 162
8390 to 8310
1. Jumper resistor is a resistor (not actually a resistor) with 0 ohm value, usually colored green with 0 markings.
Wire can also be use instead, but must not be very thin and should be as short as possible. Thin and long wire will introduce high inductive reactance and will result to weak received signal.
2. T500 can be taken from 3310 unit. It is located just above HAGAR, refer to your service manual to easily locate it. Also take note to its pin orientation during installation.
Bypassing Z551 with wires is not recommended,this will weaken the receiver sensitivity due to incorrect signal phase relationship.
3. Give special attention when installing VCO, improper positioning will result to no network activity
Old 01-02-2010, 23:07   #5 (permalink)
Member: 608240
Thanks Meter: 162
6800a to 6800
do as in picture.
Old 01-02-2010, 23:08   #6 (permalink)
Member: 608240
Thanks Meter: 162
ngage qd rh47 to ngage qd rh29
DO HARDWARE AS SHOWN IN PICTURE.
1- Erase
2- Flash MCU and PPM (Ngage Qd Rh-29)
3- Write pm
4- Init lock
Old 01-02-2010, 23:08   #7 (permalink)
Member: 608240
Thanks Meter: 162
6102 TO 6101
FOLLOW THE PICTURE.
Old 01-02-2010, 23:09   #8 (permalink)
Member: 608240
Thanks Meter: 162
2651 TO 2650
CHANGE FILTERS,FLASH WITH 2650 FLASH FILES AND WRITE GOOD PM FILE.
Old 01-02-2010, 23:10   #9 (permalink)
Member: 608240
Thanks Meter: 162
here is nokia 3390b to 3310 converting solution.
full flash with 3310 firmware and do hardware like in picture.
Old 01-02-2010, 23:10   #10 (permalink)
Member: 608240
Thanks Meter: 162
6010 to 3510i Convertion
Old 01-02-2010, 23:11   #11 (permalink)
Member: 608240
Thanks Meter: 162
6030b to 6030
Procedure:
1. like RM225 (6030b) convertion jumper or change two filters
2. write good pm 6030.pm
3. full UI settings anf unlock
riders is offline Reply With Quote
Old 01-02-2010, 23:12   #12 (permalink)
Member: 608240
Thanks Meter: 162
1100b-1100
Procedure:
1. erase flash
2. flash with 1100(rh18)
3. change filters
4. write pm
5. unlock
Old 01-02-2010, 23:12   #13 (permalink)
Member: 608240
Thanks Meter: 162
1110-1600
Procedure:
Convert Nokia 1110 (RH-70) to 1600 (RH-64) (display)
Replace the display module from 1110 with coloured module from 1600.
Flash the phone with 1600 flash files and make full factory reset.
Its not neccessary to flash the phone with 1600 flash files,
if you don't have flash equipment!
Old 01-02-2010, 23:13   #14 (permalink)
Member: 608240
Thanks Meter: 162
Convert Your Nokia BB5 Phones (850/950 mhz to 900/1800 mhz)
Also now you can convert 5200b to 5200 to work on 900mhz and using HWK , BOOM.
Rm-174_CCCCmt.bin
Rm-174_HWCCmt.bin
from option CERT .
That's all and now your phone work 100%
and if you have phone 5300b need to convert it to 5300 regular
Rm-146_CCCCmt.bin
Rm-146_HWCCmt.bin
and your phone now converted sucessfully
NB : Please make backup 308.1 pm and RPL before doing any thing .
Old 01-02-2010, 23:13   #15 (permalink)
Member: 608240
Thanks Meter: 162
6030b to 6030
1. Change the rx filter 6030b got it any other phone(nokia 3100)
2. Full flash with 6030 files(Mcu+ppm+cnt)
3. Write a good pm
4. unlock
How to change CID 49 to another ? aminnovelty DreamBox 2 11-02-2009 07:55
another model to add in MT box pro Aloservice MT-BOX 2 09-06-2007 19:52
Change Nokia 8801 to Nokia 8800 elassooudi Nokia Hardware & Hardware Repair 1 10-30-2006 11:39
Change nokia 3620 to 3660 through sofware manupilation? fisho WD2 & APE (Symbian Phones) 1 06-03-2005 07:12
Page generated in 0.20380 seconds with 9 queries
