05-20-2002, 21:11 | #1 (permalink) |
No Life Poster Join Date: Dec 2001 Location: In front of my computer
Member: 7741 Status: Offline Thanks Meter: 111 | changed COBBA IC, but no signal i try to change the COBBA ic and then I calculate the Faid using Eeprom Tools 3.01, but i don't get signal! And the msid is 000001101001 (something like that) Why |
05-20-2002, 21:40 | #2 (permalink) |
No Life Poster Join Date: Aug 2001 Location: P A K I S T A N _____________ Age: 40
Member: 5932 Status: Offline Thanks Meter: 1,694 | if your MSID is like this 000001101001 u need to flash MCU+PPM to phone.. after that check... otherwise post in hardware repair section for better response. Best Regards, WaHaB Last edited by DrMobile; 05-20-2002 at 21:43. |
05-21-2002, 07:03 | #4 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Croatia Age: 45
Member: 4185 Status: Offline Thanks Meter: 3 | Not true. You dont need any calibration...... Write mcu+ppm to phone and then calculate FAID... if not work write new EEPROM (virgin if u have),change imei,calculatze faid and all ok....... |
05-21-2002, 08:16 | #5 (permalink) |
Freak Poster Join Date: Feb 2002
Member: 9254 Status: Offline Thanks Meter: 4 | COBBA stores RF A/D values Change COBBA = CHANGED RF A/D values = SIGNAL PROBLEMS Nokia Mobile Phones Service Bulletin No. SB-061/19.11.01 Technical Support, Europe & Africa NSM-3 NEW COBBA VERSION (4370793) Due to material availability new COBBA version has been released for NSM-3. New COBBA (4370793) is backward compatible with previous COBBA version (4370643). Old material in stock can be used, but new spare part orders must be placed to code 4370793. Note: When COBBA is changed IMEI rebuild and RF tunings must be carried out. CODE ITEM PG DESCRIPTION Old 4370643 N250 35 COBBA_GJP V4.1 V257BG64T/8 BGA64 New 4370793 N250 35 COBBA_GJP V4.1 V257JG64T/8 BGA64 |
05-21-2002, 08:26 | #6 (permalink) |
Member: 4185 Status: Offline Thanks Meter: 3 | So why i never had to calibrate rf when i changed cobba? I only changed cobba,write new eeprom,change imei,flash mcu+ppm ,calc FAID....and all ok.....? |
05-21-2002, 15:58 | #7 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Karabakh - Azeris motherland Age: 45
Member: 9856 Status: Offline Thanks Meter: 2 | M@RTY YOU ARE NOT RIGHT!!! It does not matter which COBBA you put unless the type is the same! OK! Maybe phone will not work as good as before, but it will work without significant problem. The guy who can not get tx power should write good eeprom and calculate imei & faid programming data! That`s it. No need to argue. Already tested by me on tenth of units! Best Regards BufferMess |
05-22-2002, 05:55 | #9 (permalink) | |
Member: 9254 Status: Offline Thanks Meter: 4 | Quote:
The answer is you took cobba from old pcb which would still have RF A/D values stored for that phone , no two phones have the same RF A/D values due to tolerences in components , the phone will never be 100% until RF is calibrated. New pre-balled cobba i.c's are blank , thats why ALL nokia service material about changing cobba states RX/TX values must be re-aligned. @ BufferMess "That`s it. No need to argue. Already tested by me on tenth of units!"...............Who is argueing ? , i am only giving my advice. B.R M@RTY | |
05-22-2002, 22:02 | #10 (permalink) |
Member: 7741 Status: Offline Thanks Meter: 111 | All of u are confusing me!!! I've tried changing the 3310 (NSM-5) COBBA (which i didn't notice the type), and it is still de same I've done this:- write MCU=200000-330000 write PPM=330000-3D0000 Write Virgin Eeprom=3D00000 Then i correct the IMEI, calculate the Faid, and reset the SP lock. BUT i still don't get the SIGNAL!!! |
05-22-2002, 22:14 | #11 (permalink) | |
Member: 5932 Status: Offline Thanks Meter: 1,694 | Quote:
Why u chnage cobba. Before changing Cobba network is working.. and one more question After changing Cobba u got totally no signals or signals for 5 seconds than no signals. Best Regards, WaHaB | |
05-22-2002, 22:36 | #12 (permalink) |
Member: 7741 Status: Offline Thanks Meter: 111 | Change COBBA is because there's no ear volume sound can't hear other people talking(SPEAKER), so have to change because already tried reflow but no success |
05-23-2002, 01:10 | #13 (permalink) | |
No Life Poster Join Date: Mar 2001 Location: Earth
Member: 3506 Status: Offline Thanks Meter: 6 | hi M@RTY, where ca I find test and repair nokia equipment??? thanks Quote:
05-23-2002, 15:06 | #14 (permalink) |
Member: 9856 Status: Offline Thanks Meter: 2 | Nowhere! Nokia original GSM Tester is a huge collection of equipment which costs high enough to make us ------>>>>>> M@RTY: OK! You were giving advice. Sorry for that! But you were insisting on your claim. Theoretically, you are right! However, don`t forget that we are conversating in GSM Forum not in Nokia Service Centres Meeting. Nobody here have such an equiplement nor such money to invest. RF values in the virgin eeprom are quite enough to run the phone without problems in any network. It was tested hundred times by many people in this forum. Works perfectly! hooi76: After changing COBBA msid will be like as you saw. Just write virgin eeprom and calculate necessary data. Don`t forget that new models of COBBA are backward compatible but older ones are NOT forward compatible! Best Regards BufferMess |
2630 imei change but no signal | vicky784 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 04-27-2010 09:42 |
nokia 6030 ringer ic jumper i will change ringer ic but not work please post image | prakash40 | Nokia Hardware & Hardware Repair | 2 | 09-20-2009 03:07 |
6070 menu key not work. change key ic but still not working | timopmass | Nokia Hardware & Hardware Repair | 5 | 08-10-2008 22:14 |
anyone in uk change cobba ic on 8210 (no siginal) | Mc Gáv | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-19-2002 20:27 |
3310 has signal but no signal strength indicator | brittnee | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 04-23-2001 02:01 |
