04-22-2003, 18:24 | #1 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Flash Age: 44
Member: 11208 Status: Offline Thanks Meter: 11 | 3310 contact service even change cobba? Today customer brought to me 3310 show CS. I tested with wintesla then it says cobba serial failed. I tried to change more than 10 new cobba still same. Also I changed around component near cobba,and ccont. But stll same. Now only faulty unit suspect is MAD or not? Bye. |
04-23-2003, 10:23 | #5 (permalink) |
Freak Poster Join Date: Sep 2002 Location: Nokialand Age: 43
Member: 15909 Status: Offline Thanks Meter: 0 | Cobbaif is communication&clocksynchron line to Mad. (cobba A7-B7-D8 pins to Mad2 A6-A7-C6). If cobbaif line is faulty, Mad2 not see cobba. Remove cobba, and check: Cobba A7 to J316 (CPU A7) Cobba D8 to J317 (CpU c6) and B7 to j315 (CPU A6) |
07-20-2004, 10:48 | #7 (permalink) |
No Life Poster Join Date: May 2004 Location: gsm-land Age: 45
Member: 67419 Status: Offline Thanks Meter: 237 | @gsm salers contact service in cobba is 2 kind cobba serial and cobba paralel and you must change 10000x cobba and contact service is still alive.you must see better down cobba on the pinsthey are disconected and your job is to solder them one by one with atention and your problem will resolved best regards keany |
07-20-2004, 10:50 | #8 (permalink) |
Member: 67419 Status: Offline Thanks Meter: 237 | @gsm salers contact service in cobba is 2 kind cobba serial and cobba paralel and you must change 10000x cobba and contact service is still alive.you must see better down cobba on the pinsthey are disconected and your job is to solder them one by one with atention and your problem will resolved best regards keany this post is in 2003 what hapened with you??' |
07-22-2004, 21:57 | #13 (permalink) |
Freak Poster Join Date: May 2003 Age: 48
Member: 29870 Status: Offline Thanks Meter: 24 | @gsmsalers I suggest you to change flash IC and if needed write good flash.Usually when I change cobba and don't solve problem I change flash and give good result. post result please. |
3110c contact service even after successfull flashing | gsm_era | MT-BOX | 11 | 10-10-2010 10:34 |
1600 contact service even after jumper solution??? | kamiran | Nokia Hardware & Hardware Repair | 8 | 05-18-2008 13:54 |
3310 contact service with cobba fail when test | olujimi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-07-2005 08:13 |
3310 contact service insert sim/contact i tried ... | makona | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-11-2001 04:38 |
3310 contact service repair? | emix | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-04-2001 21:47 |
