11-07-2002, 17:24 | #1 (permalink) |
Junior Member Join Date: Nov 2001 Location: Sampaloc
Member: 7545 Status: Offline Thanks Meter: 0 | Flash erase check (battery voltage too low) the phone is 3310, it used to be "contact service" and when i check through wintesla, it's the eeprom tune checksum that has problem. however, if i flash virgin eeprom to the phone, it displays something like the loader is not correct but if i change mcu-ppm, it writes smoothly. i tried to reheat flash ic thinking that it might be a connection problem but after that, the flasher already displays "battery voltage too low" even if the battery is fully charged and even if i put a regulated power supply to the phone. do you have any solution to this? BR |
11-07-2002, 17:39 | #2 (permalink) |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | scanner If wintesla show " eeprom tune checksum ", then you just have it to "DEV" reset ! VPP, you need to check VB and D304 for VPP supply ! and look like your CCONT (VB) and flash rom you have to replace it ! Willy |
8250 flash erasing error(battery voltage is too low) | gama_cell99 | Nokia Hardware & Hardware Repair | 8 | 06-01-2005 17:09 |
8250 flash erasing error(battery voltage is too low) | gama_cell99 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 05-23-2005 06:01 |
3310 flash erasing error (battery voltage is too low) | pana_java | Nokia Hardware & Hardware Repair | 2 | 04-04-2005 14:46 |
6210 flash erase check | pali | Nokia Hardware & Hardware Repair | 1 | 03-17-2005 01:25 |
Flash erase check (battery voltage too low) | scanner | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 11-08-2002 17:04 |
