05-16-2003, 00:29 | #1 (permalink) |
Freak Poster Join Date: Dec 2001 Location: Portugal
Member: 7985 Status: Offline Thanks Meter: 0 | 8210 proble,?? i´m beginnig to repair phones and i have some questions that i would like to know : i have a hot air station 902+, i put the temperature at 300ºC, i think is right ?? i have a 8210 with no network, when i switch it on, he have network for 3 seconds and then no more, i try to search network manual and it get all but takes a lot, is PA or antenna switch problem?? if its near the PC monitor it blink sometimes like if im receiving a call? the cover of the zone where is PA and antenna switch must be taken to change/ repair the components in 8210, wich is the best way to take it out?? and the best way to put it on the right place again? Sorry for all this question, but i already read old posts and i´m a little confuse. Thanks for all replies... |
05-16-2003, 02:27 | #2 (permalink) |
Junior Member Join Date: Apr 2003 Location: CENTRAL JAVA - INDONESIA Age: 50
Member: 26504 Status: Offline Thanks Meter: 0 | Re: 8210 proble,?? You used hot air station 902+, i put the temperature at 300ºC, it is right enough Your problem : For 8210 with no network, when u switch it on, only have network for 3 seconds and then no more, u try to search network manual and it get all but takes a lot, Solution : I think there is diplexor (antenna switch) problem. Cause if its near the PC monitor it blink sometimes like if im receiving a call, so the phone ''can transmit but cannot received ok'', means the PA is already ok but the duplexor is not ok. To change/ repair the components just easy like plug and play.. but be carefull... more safe if you using flux for take the duplexer... |
05-16-2003, 07:21 | #3 (permalink) |
Member: 7985 Status: Offline Thanks Meter: 0 | i will try, but put flex to take it off?? and this question: the cover of the zone where is PA and antenna switch must be taken to change/ repair the components in 8210, wich is the best way to take it out?? and the best way to put it on the right place again? tks |
05-17-2003, 03:27 | #5 (permalink) |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | YeTi, if your PA and antenna Switch is replaced then: try to see that 32.768Khz sleep clock by run ring tone, see it slow or you can put a charger check charger bar run speed ! if it is normal, then you go to replace 26Mhz Willy |
05-18-2003, 22:43 | #7 (permalink) |
Freak Poster Join Date: Oct 2001 Age: 41
Member: 7072 Status: Offline Thanks Meter: 10 | first replace PFO and if it doesnt work than change antena switch. work carefuly and try not to demage any litle components around PFO and switch. That should solve your problem for 99.99% |
05-29-2003, 22:20 | #9 (permalink) |
Member: 7985 Status: Offline Thanks Meter: 0 | hi, i already replace PA and now i have network but each minute it loose and after 5 seconds have full network again, this is always repeating each minute, solution?? tks |
2618 netw probl. | sasko2 | Sony Ericsson Hardware Repair | 2 | 09-14-2003 17:35 |
33XX Csipogó probléma | nagyelek | Nokia Hardware & Hardware Repair | 3 | 06-18-2003 14:34 |
8210 signal probl | uwenk98 | Nokia Hardware & Hardware Repair | 3 | 02-08-2003 06:16 |
proble with SimScan v1.21 | gabriel | Hardware Equipments for GSM | 0 | 11-28-2001 20:47 |
Proble to unlock T28 WORLD ver. 00W29 from Pacific Bell | sashpeto | Old Ericsson Phones & Sony Phones | 10 | 08-24-2000 06:49 |
