04-12-2009, 12:42 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Location: KOLKATA Age: 51
Member: 102582 Status: Offline Thanks Meter: 72 | Dead Nokia 3220 Showing Message in UFS-3+HWK One dead nokia 3220 came to me. I have reballed the CPU & the COMBO Memory successfully. Now, the switching voltage is showing 2.76 v, Charging voltage is showing 3.54 v when I insert the charger. The set is still lying dead. When I put it into UFS-3+HWK, it's showing the following message : 1st Boot Err: Bad Resp UPP, FF FF FF 72 1st Boot Err: Bad Resp DCT3, 00 93 5 Rebooting Mobile Is this CPU/UPP Problem? Pls. give me the solution. Thanks in advance, amit123 |
04-12-2009, 14:56 | #3 (permalink) |
Member: 102582 Status: Offline Thanks Meter: 72 | Dear xEDIx, Would you kindly clarify me that How do I understand from the above message of (UFS-3+HWK) that which one is the fault of cpu, which one is the fault of FLASH IC and which one is the fault of UEM? As UFS returns following messages at different times : 1. 1st Boot Err: Bad Resp UPP, FF FF FF 72 1st Boot Err: Bad Resp DCT3, 00 93 5 Rebooting Mobile 2. 1st Boot Err: Bad Resp UPP, 00 FF FF 72 1st Boot Err: Bad Resp DCT3, 00 93 5 Rebooting Mobile 3. 1st Boot Err: Bad Resp UPP, 01 FF FF 72 1st Boot Err: Bad Resp DCT3, 00 93 5 Rebooting Mobile 4. 1st Boot Err: Bad Resp UPP, 02 FF FF 72 1st Boot Err: Bad Resp DCT3, 00 93 5 Rebooting Mobile 5. 1st Boot Err: Bad Resp UPP, 03 FF FF 72 1st Boot Err: Bad Resp DCT3, 00 93 5 Rebooting Mobile 6. 1st Boot Err: Bad Resp DCT3, 00/01/02/03 FF FF 72 1st Boot Err: Bad Resp UPP, 00 FF FF 72 Rebooting Mobile Pls. give me your valuable suggestions. I think it will come to help for our other beloved members as well. Advance thanks to all. amit123 |
09-26-2010, 13:22 | #5 (permalink) |
Junior Member Join Date: Dec 2006
Member: 414358 Status: Offline Thanks Meter: 2 | 1st Boot: Ok, DCT4, UPP: 2142 [Rh-37] [2.1.0.1] 2nd Boot: u_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x01FFFFFF,00208804,St M36L0R7040U Algorithm: u_intel.fia, Ver: 4.80.0 Algorithm Ok, MSID: 84B17477A14038EAF7011BD0B1 Decoded MSID: 1C15BAE3-009819BD-AD0005BD Encoded FAID: C2642836-B78D8F8F-59E1C111 Chip SECTOR_SIZE: 128k, File FAT_SECTOR_SIZE: 64k Warning, Must be Used 128Kb Sector_Size CNT File IMAGE: rh37__06.22.image_india_128 Area1: 0x01A40000-0x01E5FFFF Erased, Time: 00:40 CNT Flashing Completed, Time: 00:14 Extracting Contents Package ... Init Local Mode Failed Contents Package Extracting Failed: Process Failed, Repowering Mobile |
09-26-2010, 13:26 | #6 (permalink) |
Member: 414358 Status: Offline Thanks Meter: 2 | When I put it into UFS-3+HWK, it's showing the following message : 1st Boot: Ok, DCT4, UPP: 2142 [Rh-37] [2.1.0.1] 2nd Boot: u_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x01FFFFFF,00208804,St M36L0R7040U Algorithm: u_intel.fia, Ver: 4.80.0 Algorithm Ok, MSID: 84B17477A14038EAF7011BD0B1 Decoded MSID: 1C15BAE3-009819BD-AD0005BD Encoded FAID: C2642836-B78D8F8F-59E1C111 Chip SECTOR_SIZE: 128k, File FAT_SECTOR_SIZE: 64k Warning, Must be Used 128Kb Sector_Size CNT File IMAGE: rh37__06.22.image_india_128 Area1: 0x01A40000-0x01E5FFFF Erased, Time: 00:40 CNT Flashing Completed, Time: 00:14 Extracting Contents Package ... Init Local Mode Failed Contents Package Extracting Failed: Process Failed, Repowering Mobile |
DEAD N-70[RM-84] shows in UFS-3... | amit123 | Nokia Hardware & Hardware Repair | 2 | 05-21-2009 12:15 |
Dead nokia 3310 showing in original ufs-3+hwk. | amit123 | Nokia Hardware & Hardware Repair | 1 | 05-09-2009 07:51 |
Sony ericsson falshing procedure in ufs-3+hwk? | amit123 | Sony Ericsson Hardware Repair | 0 | 11-06-2008 06:13 |
Dead Nokia 5200 giving message in UFS-3+HWK... | amit123 | Nokia Hardware & Hardware Repair | 0 | 10-30-2008 07:42 |
Nokia 3120 Dead Set Showing Msg.In UFS-2.08.0 | amit123 | Nokia Hardware & Hardware Repair | 2 | 10-01-2008 11:39 |
