02-15-2013, 06:39 | #4 (permalink) |
Freak Poster Join Date: May 2007
Member: 515100 Status: Offline Thanks Meter: 73 | first change flex cable. its light problem bro remove touch n look closly ull see display withot light so jst repair light problem, and how can someone solve light issue with flashing grow up buddy |
02-16-2013, 06:03 | #11 (permalink) |
No Life Poster Join Date: Oct 2012 Location: india
Member: 1825795 Status: Offline Sonork: 100.1621021:98 Thanks Meter: 183 | hi broo all ok change flex change lcd same condition and some time it work but after that same problem flesh latest files but same and also done ok after flesh many times but in this set same ...................................... any one tested solution plzz update and when phone goes on lcd lite come 3 sec then lcd light go off and phone start and touch not works only on off button working under touch ..................... |
02-16-2013, 06:43 | #12 (permalink) |
No Life Poster Join Date: Feb 2012 Location: kanpur
Member: 1722956 Status: Offline Sonork: mybestfriend.adeel Thanks Meter: 305 | i have solved this kind of problem by changing infinion power and flash ic from same other pcb. i made yesterday c2-03 white display problem.i changed both ic from other dead board and set had been on. tested and final solution if your pcb is not water damage. |
