09-13-2009, 19:29 | #1 (permalink) |
Product Manager Join Date: Sep 2003 Location: Indonesia Age: 45
Member: 39251 Status: Online Sonork: 100.1618715 Thanks Meter: 6,140 | Detail Analisys N70 Blank by ichal spy... 1. blank because Display Problem 2. Blank because omap problem (Product selection missmatch) 3. Blank because Ape Flash problem Analysis : 1. Blank because Display Problem : characteristic : - flash OK... until finish - Local mode and normal mode ok - can make call Solution : - Change LCD - Cek LCD Connector - Cek Lcd Voltage (vcc) : Vio 1.8v and Vaux 2.8v if there is no voltage... make a jumper from other same voltage - Cek Emif Display... change id if need or make a jumper - Change OMAP here jumper trick for display emif 2. Blank because omap problem (Product selection missmatch) characteristic : - White screen on display - when flashing with Ufs there is error message "PRODUCT SELECTION MISSMATCH" Solution : 1. Cek Vcorea 1.4v, if there is no voltage... make remove SMPS then make jumper from Vcore to Vcorea 2. Cek Vio for OMAP, if no suply make a jumper from another vio from Rap3G 3. Cek PURx for OMAP, if no 1.8v, make a jumper from PURS Retu 4. Cek Ape sleepx, if no 1.8v, reball RAP3G 5. Iff all OK... reball or change OMAP trik jumper for Vcorea problem 3. Blank because Ape Flash problem characteristic : - Blank at display - Camera Light is on continously - When flashing there is error message "Ape Boot Error" Solution : - Check Vio for Ape flash, if no voltage jumper from another vio or from Vdra, - cek Vddrape, if no voltage, remove Ape regulator then make a jumper from Vio to Vddr ape - If all om, Change or reball Ape flash (Combo flash) Jumper trik for vddr ape problem : Note : Buang = Remove |
The Following 43 Users Say Thank You to Rizal Arsyad Dini For This Useful Post: |
09-13-2009, 23:29 | #3 (permalink) |
No Life Poster Join Date: Sep 2008 Location: The Land Of Promise
Member: 857401 Status: Offline Sonork: 1596086 Thanks Meter: 129 | good job brother hope you will post other solutions in nokia models |
The Following User Says Thank You to dabing For This Useful Post: |
09-14-2009, 06:41 | #8 (permalink) |
Major Poster Join Date: Jan 2003 Location: alex of egypt Age: 53
Member: 20500 Status: Offline Thanks Meter: 4 | well well thats we realy need mr i chal spay but it will be better to add if the phont totaly died with no responce in ufs and what about using your nice tools frequncy counter and oselloscope thanks alot for your great post |
09-14-2009, 08:08 | #11 (permalink) |
No Life Poster Join Date: Jun 2007 Location: INDONESIA
Member: 527741 Status: Offline Thanks Meter: 355 | which I often fail bro, you have another solution trik jumper for Vcorea problem http://i291.photobucket.com/albums/l...ssmatchn70.jpg saludos |
The Following User Says Thank You to ucokmonalisa For This Useful Post: |
09-14-2009, 08:17 | #12 (permalink) | |
Member: 39251 Status: Online Sonork: 100.1618715 Thanks Meter: 6,140 | Quote:
if all ok.. the problem at OMAP | |
09-15-2009, 16:12 | #15 (permalink) | |
Freak Poster Join Date: Apr 2006
Member: 254086 Status: Offline Thanks Meter: 24 | couldnt get this N70 screen problem Quote:
sir i hve one n70 it has screen problem or software problem icant get it bcs when i mswitching on the phone phone swicth on but on the left side of screen i can see small size squre in blue clur n rest of screen like dot i can hear the soundoff nokia LOGo after that sound phone screen showing in white but with HWK this the chek 1ST BOOT : C0,0C [] [2.0.9.0] OMAP ID : 17100701 OMAP MODE : 00 OMAP PBID : E2C7BE967DE415105BEF5E4F24DB949C613CAB4A OMAP HASH : 2C05369F57CC3C4CF9E783E83D9B512B OMAP ROID : AB5E4ADB27A06946 RAPx ID : 000000010000022600010006000C192101002200 EM 1 ID : 00000232 EM 2 ID : 00000353 RAPx PBID : 16F0000306755D51B1A9B884BC2A75302279AD85 RAPx MODE : 00 RAPx HASH : E9EFF4BFAA5393217CA6B17755FC3E14 RAPx ROID : F28A211FCEA7B19D CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv2_2nd.fg, Ver: 1.21.0 CMT FLID0 : 00EC2250-00000121, Sam K8S6415ETB CMT FLCNT : 00000000000000000000000000000000000000 CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.17.0 CMT KSIG0 : 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D CMT VPP : Internal DUAL LINE : True CMT ALG Boot OK APE 2ND Bt: helen3_2nd.fg, Ver: 1.35.0 APE FLID0 : 00980036-00A500C0, Tos NAND-512 APE RQALG : OMAP1610 GBBM-1.8.1 ALG APE FLCNT : 01010000020000000600000000000000000000 APE 2ND Boot OK APE ALG0 : h3_sam_nand_gbbm.fg, Ver: 1.33.0 APE VPP : Internal APE KSIG1 : 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D DUAL LINE : True APE ALG Boot OK Rebooting Mobile N this the info MCU SW : V 05wk07v48.1 28-08-07 RM-84 (c) Nokia. APE Core: V 5.0737.3.0.1 13-09-07 RM-84 (C)Nokia APE Var : V 5.0737.3.0.1-01.01 13-09-07 RM-84 (c)Nokia. Prd.Code: 0522157 Bpr.Code: 0522156 Prod.Sn : CPH573281 HW Vers : 7003 APE HW : 256 APE Adsp: 16054 EM RETU : 32 EM TAHVO: 53 RFIC Ver: 150a160f DSP Vers: rolf_05wk07v29p1 LCD Type: 0 IMEI : 358637-01-986900-4 SL Serv : SIMLOCK SERVER VERSION 58 SL Conf : 244-07-00000000000 SL Prof : 0000000000000000 SL Count: 00 00 BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN Provider: Nokia Test;Finland but icant see the Test mode N Local mode what the solution off this phone | |
The simplest N70 blank LCD (non complete booted) solution !!! | mobilagy | Nokia Hardware & Hardware Repair | 29 | 09-05-2010 00:23 |
N70 Blank display and Flash light Very urgent | naseer_10_1980 | Nokia Base Band 5 ( BB-5 ) | 14 | 04-22-2008 21:00 |
N70 blank display | mobilemaster | Nokia Hardware & Hardware Repair | 8 | 02-28-2008 20:54 |
n70 blank lcd | simonmanju | Nokia Hardware & Hardware Repair | 2 | 08-26-2007 11:37 |
N70 Blank Screen | J-lock | Nokia Base Band 5 ( BB-5 ) | 1 | 02-17-2007 14:55 |
