Old 12-10-2010, 02:24   #1 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
..::5610 charging ok but discharge very fast::..
5610 charging ok but discharge very fast without using mobile
i change betty 2 times but still same
set not short
change battery
Old 12-10-2010, 02:51   #2 (permalink)
Member: 285779
Thanks Meter: 49
on phone see is the bluetooth working normal ?
is drain fast without simcard ?
yes ?
-> go to power ic
Old 12-10-2010, 13:38   #3 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
bluetooth work fine but think its bt ic problem?
Old 12-10-2010, 14:20   #4 (permalink)
ramjan_777's Avatar
Member: 1226253
Sonork: 1602755
Thanks Meter: 69
br. check power suplay set and swicheng verry first
to remove bt ic
Old 12-10-2010, 14:33   #5 (permalink)
Member: 285779
Thanks Meter: 49
what if without simcard ? still drain quik ?
bt ic show nothing error , but still have posible .
why dont try avilma 1st , easier to do , also controlling power
Old 12-10-2010, 14:39   #6 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
already change avilma and betty twice
Old 12-10-2010, 23:54   #7 (permalink)
Member: 601591
Thanks Meter: 86
hi is the set getting hot when it is working?
secondly did you see anything like water inside the board?
the most problem with quick discharging is water when is entering
the set it will bridge the power ic or those black bg this now let the set
works abnormal.so just protect the mic ,clean the board very well n heat
it round to dry all the affected area.
Charging. PhoeniX Nokia Hardware & Hardware Repair 7 07-06-2004 08:35
Unlocked network on 5110v5.28 does not make calls, but other network does? Prodigal Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 03-01-2001 16:43
NOKIA 5110 5.29 all locks OPEN but SIM CARD NOT ACCEPTED elektron code ECS Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 01-10-2001 17:40
FBUS works but MBUS not! PLS Help! Upo Nokia Hardware & Hardware Repair 5 09-12-2000 14:54
6110 unlocked but wont give reception KingOfKingston Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 04-10-2000 22:15
Page generated in 0.33008 seconds with 9 queries
