11-01-2013, 17:38 | #1 (permalink) |
Junior Member Join Date: Feb 2013
Member: 1882288 Status: Offline Thanks Meter: 0 | e63 pfo complaint-help me the temp settings in hot air gun battery positive power to pfo ok-in manual search provider list ok.but when select no acess. i think my temperature settings in hot air gun high-so damaged when fixing. whats the temperature to remove pfo? or any other more accurate equipments to fix pfo? |
11-01-2013, 20:53 | #2 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | yeap , no acess generally came faulty PA . seems u overheat PA . try to use preheater to heat pcb from down side & use maximum 180'c t ofix new PA . u may also use infrared rework station to fix PA . |
11-02-2013, 07:30 | #3 (permalink) | |
Member: 1882288 Status: Offline Thanks Meter: 0 | Quote:
for pfo replace ir station better than hot air gun? e63 pfo in any other nokia motherboards? | |
