Old 11-15-2007, 05:35   #1 (permalink)
Member: 609370
Thanks Meter: 13
6600 white screen -two flash ic's detected-then an error-help
i have a 6600 white screen -two flash ic's detected-then an error as below
1st Boot Ok, WD2, UPP: 1081
Fl0: 0x00000000-0x007FFFFF,002088C0,St M28W640
Fl1: 0x02000000-0x027FFFFF,002088C0,St M28W640
Algorithm: w3_st_i.fia, w3_cbusb.fia, Ver: 4.49.0
Alg Boot Error: 2
Error Data1:
00000000: 9B 00 04 00 20 00 C0 88 00 00 00 00 02 20 00 C0 .... ........ ..
00000010: 88 00 00 00 00 04 20 00 C0 88 00 00 00 00 06 20 ...... ........
00000020: 00 C0 88 00 00 00 00 C6 00 00 EA 75 01 00 EA 78 ...........u...x
00000030: 01 00 EA 7B 01 00 EA 76 00 00 00 00 00 00 00 00 ...{...v........
Error Data2:
00000000: D3 72 00 C0 88 00 00 00 00 02 20 00 C0 88 00 00 .r........ .....
00000010: 00 00 04 20 00 C0 88 00 00 00 00 06 20 00 C0 88 ... ........ ...
00000020: 00 00 00 00 C6 00 00 EA 75 01 00 EA 78 01 00 EA ........u...x...
00000030: 7B 01 00 EA 76 D3 72 00 00 00 00 00 00 00 00 00 {...v.r.........
Before taking screenshot, expand this window !
Process Failed, Repowering Mobile
i know F10 is ic D314----F11 is D315---F12 =D316 AND F13=D317 DID NOT DETECT.MY DOUBT IS BOTH D316 AND D317 FAULTY?
Old 11-15-2007, 05:59   #2 (permalink)
neetika99's Avatar
Member: 588837
Thanks Meter: 146
give some heat 2 flash ics...than earse flash ...flash with *fia files/////now flash with latest files//////////////post result
Old 11-15-2007, 08:21   #3 (permalink)
Registered User
Member: 483748
Thanks Meter: 47
u have to take out both and then mount it again ur problem will be solved.
6600 White Screen-first Boot Ok-second Boot Error 2-help zone2 Nokia Hardware & Hardware Repair 2 11-14-2007 16:52
V3 Bootloader Screen-did Repair Pds-then Tried Flash -an Error-help zonetrichur Smart-Clip 6 10-30-2007 09:07
W300 white screen, already flashed, no errors but still white screen enrocas Cruiser Suite 6 11-29-2006 19:57
nokia 6600 white screen after flashing pitodenz Nokia Hardware & Hardware Repair 0 08-06-2006 18:34
6600 White Screen Then Powers Off .... Byte Nokia Hardware & Hardware Repair 2 08-15-2005 14:38
Page generated in 0.15741 seconds with 9 queries
