11-11-2008, 13:26 | #1 (permalink) |
Freak Poster Join Date: Oct 2006 Location: South Africa Age: 48
Member: 372599 Status: Offline Thanks Meter: 41 | E65 Not Charging problem.. Need help please I have Nokia E65 which was little bit water damage on charging points.. i clean it nicely and i did check the tracks with buzer also everything seems fine.. but as i put charger in the phone it shows not charging.. even i try to change the battery and charger but still same.. i need help please.. if anyone knows about this problem to solve.. thanks |
11-11-2008, 14:10 | #2 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Roumania
Member: 461923 Status: Offline Thanks Meter: 2,020 | Quote:
The Following User Says Thank You to stefani For This Useful Post: |
11-11-2008, 14:39 | #3 (permalink) |
Member: 372599 Status: Offline Thanks Meter: 41 | thanks for replying.. i did try this method but u did not understand my problem.. my problem is not " charger not supported" problem is when i put charger in it quickly says.. Not Charging.. thanks |
N500 not charging problem????pls help??? | proxy_gsm | VLSI, Conexant, Skyworks and Old Models | 9 | 08-11-2013 17:56 |
1208 charging problem need help | /\/\A/\/| | Nokia Hardware & Hardware Repair | 3 | 06-26-2009 20:53 |
3230 not charging problem,,,need solution. | manish665 | WD2 & APE (Symbian Phones) | 4 | 04-11-2009 06:09 |
3110c charging problem need help | pradeepmishra | Nokia Hardware & Hardware Repair | 3 | 01-09-2009 04:56 |
n3210, charging problem. need help | pali | Nokia Hardware & Hardware Repair | 3 | 07-04-2002 01:54 |
