02-17-2010, 17:46 | #1 (permalink) |
No Life Poster Join Date: Sep 2008
Member: 860880 Status: Offline Thanks Meter: 83 | e66 display problem |
09-14-2010, 15:35 | #4 (permalink) |
Freak Poster Join Date: Aug 2003 Location: Bulgaria Age: 36
Member: 37668 Status: Offline Thanks Meter: 15 | I have the same problem Hi, I have exactly the same problem. After removing the shield, the LCD goes blue/black. I will try replacing the three crystals. |
11-01-2010, 15:26 | #5 (permalink) |
Member: 37668 Status: Offline Thanks Meter: 15 | I have replaced the crystal IC's and everything is fine now ! But be very careful when soldering IC's. First remove old, clean PCB and preheat. Then put and center the new IC. After that first reflow the back side of PCB under the crystal for over 10-15 secs. After that heat the IC but for 1-2 sec. |
E66 display problem | czaren | Nokia Hardware & Hardware Repair | 10 | 09-28-2012 19:15 |
Need e66 display solution | mobifone | Nokia Hardware & Hardware Repair | 7 | 09-22-2010 06:52 |
E66 display light problem | shahzad00786 | Nokia Hardware & Hardware Repair | 1 | 05-25-2010 14:14 |
5800 Display Problem (With Display On FBUS Cable But No Display using Regular Battery | eyestrain | Nokia Base Band 5 ( BB-5 ) | 1 | 06-21-2009 20:11 |
