12-05-2009, 01:11 | #1 (permalink) |
Freak Poster Join Date: Jul 2001 Location: Poland, Gliwice Age: 43
Member: 5345 Status: Offline Thanks Meter: 29 | E71 phone does not start up SYMPTOMS Phone does not start up when pressing power key. When pressing the power key notification light and display backlight wake up. Vibra makes one jog. Phone will take 230 mA but nothing else happens. After 30 seconds phone will power off. With Phoenix you can't get connected to the phone. You can update phone software but it doesn't help anything. Phone doesn't start to test mode in Phoenix. Note! This file does not fix other issues such as if phone starts to test mode but not to normal mode. Also this file should not destroy undamaged device. HOW TO FIX 1) Flash E71_blank_504KB_pmm_10.fpsx file to phone with firmware update: Firmware Update-> Options -> select E71_blank_504KB_pmm_10.fpsx into Image field and empty other fields 2) Flash the whole SW package to phone with firmware update 3) Run factory settings Phone should work now. But this is not work, the phone not boot, If I select manually mcu,ppm, cnt the phone flashing succesfully but not power up. Any solution?? I Think this is hardware problem. |
12-05-2009, 16:35 | #6 (permalink) |
Member: 5345 Status: Offline Thanks Meter: 29 | you can also do tricks with that 1. fullflash (the same firmware.... not higher not lower) 2. on mcu select E71_blank_504KB_pmm_10.fpsx this not working, I check capacitors maybe are demage. |
The Following User Says Thank You to szozda2 For This Useful Post: |
12-16-2009, 02:24 | #8 (permalink) | |
No Life Poster Join Date: Dec 2000 Location: J.A.U - Just Another Unlocker Age: 43
Member: 2878 Status: Offline Thanks Meter: 9,123 | Quote:
with what tool you tryed to write the erase file? cause i have seen it dont work with jaf software... then i used mt box and it have worked... i have tryed it many times with jaf and have fixed many e71 with mt box and the erease file... and you need to use this file: 256MB_RAPIDO_YAWE_erase_by_mm-gsm.rar the other one whant work... first make crt imei backup, to be able to restore imei after erase... if you dont have pm308 and pm120 backup you need to repair with simlock rpl and genSX to make it fully work again. | |
12-17-2009, 02:59 | #10 (permalink) |
Member: 5345 Status: Offline Thanks Meter: 29 | helllo oOXTCOo, I'm tryed jaf box and mx-key. I have only cracked version mx-key I can only flashing and I can read phone, I can't read pm308 and pm120 backup, In jaf box the same, and in jaf box when i press check and when I press flash I have information : CMT Boot Data: Asic ID: 000000010000022600010006400C192101031103 Asic Mode ID: 00 Asic EM ID: 00000B22 Asic Public ID: 0CF0000347AC01586CAE156C0B6EC8019AE7A8FE HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE00000000 ROM ID: 4B9B75103E691FF8 Error finding cmt boot file... I have good nokia 6280 and when I press in jaf check I take good Information. I havent mt-box. |
12-17-2009, 03:19 | #11 (permalink) |
Member: 5345 Status: Offline Thanks Meter: 29 | helllo oOXTCOo, I'm tryed jaf box and mobileEx . I have only cracked version mobileEx I can only flashing and I can read phone, I can't read pm308 and pm120 backup, In jaf box the same, and in jaf box when i press check and when I press flash I have information : CMT Boot Data: Asic ID: 000000010000022600010006400C192101031103 Asic Mode ID: 00 Asic EM ID: 00000B22 Asic Public ID: 0CF0000347AC01586CAE156C0B6EC8019AE7A8FE HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE00000000 ROM ID: 4B9B75103E691FF8 Error finding cmt boot file... I have good nokia 6280 and when I press in jaf check I take good Information. I havent mt-box. |
Solution For E71 phone does not start up... | jafsupport.com | J.A.F. By Jafsupport.com | 295 | 04-16-2015 05:52 |
Solution For E51 phone does not start up... | jafsupport.com | J.A.F. By Jafsupport.com | 106 | 12-22-2012 19:05 |
my n78 phone does not start up... help! | yx724 | J.A.F. By Jafsupport.com | 7 | 06-10-2009 04:25 |
my n78 phone does not start up... help! | yx724 | Nokia Base Band 5 ( BB-5 ) | 3 | 05-08-2009 20:09 |
