E71 short 100% (0 ohm) please help hi all, my e71 short 100% (0 ohm) i have remove PA and UEM and LED DC Converter and some Condancer but my problem not solved. please help me. |
The best way to find a short- you MUST have a power supply first. 1. put the voltage to 0 on the power supply and check it is set on the high current (usually 2A), if available 2. connect the phone board, without lcd and flexes 3. rotate slowly the voltage regulator to add voltage, the current consumption will increase, and the board will ger hot 4. check by hand, by fingers WHERE it gets hot 5. if you cant see precisely where is the hot ic, but you find the hot region, tahe the brush wet with your cleaning solution- alcohol or whatever you have and met on that region. The solution will boil on the hottest component. |
nice roso ty for that share |
check battary connecter first.and then batary contrer across one capasiter |
try to remove camera ic post the result |
bro primary volt ralated check first like pa,avilma,betty etc....................... |
