06-24-2010, 19:22 | #1 (permalink) |
Major Poster Join Date: May 2007 Location: Phil
Member: 517229 Status: Offline Thanks Meter: 13 | E71 Strange Problem! (Network) When i change the network setting to GSM the Phone no Signal but you can call emergency call. In UMTS / Dual Mode the signal have 3 bars but few minutes it drop, and have it again after a while. I already change the red mark but still the same... Is the open pattern is the problem??? |
The Following 2 Users Say Thank You to jhovic For This Useful Post: |
10-22-2010, 21:47 | #5 (permalink) |
Freak Poster Join Date: May 2005 Location: sheffield, uk Age: 49
Member: 145732 Status: Offline Thanks Meter: 23 | simple solution, tried and tested, first check the connections where the antenna sits, most likely the two flexible connectors will be damaged, de solder and resolder a new pair or just hard wire them to the antenna, 100% success, its a common fault...... |
The Following User Says Thank You to mob-inter For This Useful Post: |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
