11-25-2009, 13:37 | #1 (permalink) |
Freak Poster Join Date: Apr 2008 Location: philippines
Member: 740172 Status: Offline Thanks Meter: 277 | E71 SUPERDONGLE_KEY Invalid hardware solution Phone always shut down ( when playing music, browsing to photos etc.) check on MXKEY heres the error[IMG]http://1.bp.********.com/_3KjgtwnRiWM/Sw0Yl5H2klI/AAAAAAAAACA/4W6r5EUtIEI/s320/alvine71.JPG[/IMG] The problem can be done tru RPL calculation since the RPL is still down as of the momenti decided to changed the combo ic ( RAP3G and FLASH IC ) remove the two ic (rap and flash ic) [IMG]http://3.bp.********.com/_3KjgtwnRiWM/Sw0eeuuJ7-I/AAAAAAAAACY/yKZ1K882NN0/s320/DSC00004.JPG[/IMG] After removing the two ic clean the balls [IMG]http://4.bp.********.com/_3KjgtwnRiWM/Sw0fOdnTP7I/AAAAAAAAACg/G38XcwjkoPs/s320/DSC00006.JPG[/IMG]then put the new ic in my case i got the two ic from a dead unit of same model after replacing the two ic phone now is ok heres the screenshot SUPERDONGLE_KEY VALID [IMG]http://4.bp.********.com/_3KjgtwnRiWM/Sw0g6b5f1dI/AAAAAAAAACw/6nLoHRmPfZs/s320/2.JPG[/IMG]FINISH PRODUCT READ MORE HERE |
The Following 9 Users Say Thank You to d'odders For This Useful Post: |
02-03-2010, 14:20 | #9 (permalink) |
No Life Poster Join Date: Mar 2006 Location: skyw0rk jombang
Member: 239081 Status: Offline Thanks Meter: 253 | MXKEY v3.3 revision 1.4 discussion thread v3.3 revision 1.4, Public-Release NK (Nokia Module) - Added, FREE Universal BB5 SUPERDONGLE Repair works for SLPA and SL20 and SL3 (RAP3Gv2,RAP3Gv3,RAPIDO) ~ Possible to Repair corrupted/erased SD Key which affect in SECURITY_TEST failed and WD enabled ~ Button located to [IMEI & Security->IMEI rebuild->Repair SD] - Added, Universal SUPERDONGLE Authorization Agent to reflect the SD Repair feature ~ First in World: SUPER SD/SX4 Auth also works with Original SD and Custom SD made by other tools(Mt-Box,UB,Genie) Repairing SD issue and Doing SX4 Auth has never been easier with MXKEY ~ Button located to [PM->SUPER SD Auth] - Added, Single SIMLOCK RPL backup for SL2/SL3 phones ~ Button located to [IMEI & Security->Simlock->Backup SIMLOCK RPL] - Added, Apply DSP Patch into PM upload option ~ PM308 from file will be patched instead phone`s PM. - Fixed, DCT4 bootloader bug - Minor bug fixes BB (BlackBerry module) - Initial release of BlackBerry Unlocker added to full setup. - Works with all BlackBerry models,old and new MEP. - MEP database will be updated when new MEP available. (more features will be added at future release such as: Flashing, Repair) |
02-03-2010, 18:46 | #10 (permalink) |
No Life Poster Join Date: Mar 2008 Location: JALANDHAR(PUNJAB)
Member: 727235 Status: Offline Sonork: [email protected] Thanks Meter: 1,211 | realy good sharing brother thanks |
The Following User Says Thank You to bgreat For This Useful Post: |
SUPERDONGLE_KEY invalid! what can i do ?? | comp_new2006 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 18 | 05-08-2011 09:37 |
E72 keep restarting ..... any help with hardware solution?? | abu_nairoukh | Nokia Hardware & Hardware Repair | 4 | 12-14-2010 11:10 |
7120c SUPERDONGLE_KEY invalid,SIMLOCK invalid!done. | ...sewren... | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 03-25-2010 08:09 |
Help 7310c simlock superdongle_key invalid and invalid | nardisk | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 01-29-2010 19:38 |
SUPERDONGLE_KEY invalid! | mobilewo | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 07-16-2009 20:35 |
