04-25-2009, 09:29 | #1 (permalink) |
Insane Poster Join Date: Feb 2008
Member: 705400 Status: Offline Thanks Meter: 9 | E90 microphone still not working! PIN GND to ground PIN DATA---with a LF genarator i hear the LF NOISE when i active the mic PIN VCC ---- 1,79v when i active the mic PIN CLK -----0,89v when i active the mic but with new mic still not working.Is it possible to repalce 4 pin digital mic with a simply 2 pin mic? many thanks |
The Following User Says Thank You to marcoco For This Useful Post: |
04-25-2009, 11:35 | #4 (permalink) |
No Life Poster Join Date: Jan 2006 Location: EGYPT Age: 47
Member: 217479 Status: Offline Thanks Meter: 267 | I'm not sure about pins measurement values but commonly most of similar new mics is not working !!! Another thing; it depends on how you install the new mic, my successful way to install it is not to heat directly on mic itself but to heat from down board after lifts the keyboard flake a little away from the mic area >>> hope it helps ... |
5310 & E90 ***** Mic Not Working | Sadeeq | Nokia Hardware & Hardware Repair | 11 | 06-24-2009 15:36 |
Nokia E90 keypad up not work | abc3b | Nokia Hardware & Hardware Repair | 2 | 11-28-2008 15:24 |
e90 camera switch not working | tejasr | Nokia Hardware & Hardware Repair | 0 | 09-06-2008 06:31 |
6070 menu key not work. change key ic but still not working | timopmass | Nokia Hardware & Hardware Repair | 5 | 08-10-2008 22:14 |
3310 microphone does not works | Corban | Nokia Hardware & Hardware Repair | 5 | 01-29-2002 15:11 |
