03-17-2008, 19:38 | #1 (permalink) |
No Life Poster Join Date: Mar 2004 Location: LGE
Member: 57760 Status: Offline Sonork: 100.1579298 Thanks Meter: 3,510 | Easiest way to remove glued BGA IC's |
03-18-2008, 05:26 | #3 (permalink) | |
No Life Poster Join Date: Feb 2008
Member: 706300 Status: Offline Thanks Meter: 147 | re: Quote:
03-18-2008, 08:45 | #5 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,349 | friends search in this forum for remove glued ic posted before till now there is no liqued to remove glue but you can done it by experiance good luck |
03-18-2008, 08:51 | #6 (permalink) |
Member: 706300 Status: Offline Thanks Meter: 147 | re: " i completly disagree that xperience matters in removing glued ic becz itz is very much impossible to save both ends, board prints or bga, again itz my personal view,plz dont take it negatively" |
06-02-2008, 15:08 | #11 (permalink) |
Freak Poster Join Date: May 2008 Location: Uganda
Member: 774126 Status: Offline Sonork: 100.1645006 Thanks Meter: 42 | i have ever tried to find out the chemical used to glue those ics and the chemical which can dissollve the glue is hydrazine hydrate, that's if you can get it. the other method is using any chemical that has ammonium ions. i have ever tried the latter and removed the analog ic of lg3310. it was alredy damaged and up to now i have failed to get one to replace it with |
Someone needed to show me how to remove glued UEM on Nokia's!! | MC Harami | Nokia Hardware & Hardware Repair | 17 | 02-08-2011 10:38 |
best way - how to remove glued IC | cel_phon | Nokia Hardware & Hardware Repair | 0 | 06-03-2009 05:28 |
easiest way to send SMS to 300 contacts using 9300? | MeMobile9300 | WD2 & APE (Symbian Phones) | 0 | 12-28-2006 21:49 |
video clip on how to remove glued IC! | eddierasta | Nokia Hardware & Hardware Repair | 5 | 02-10-2006 13:37 |
