Old 10-04-2010, 09:31   #1 (permalink)
Member: 277937
Thanks Meter: 48
Please select correct loader version from 'Config' menu !
Please select correct loader version from 'Config' menu ! any 1 know the perfect way of mx key
Data package directory list; which item selected?
Wintesls Directory: which item selected?
Dct4 bb5 flash loader directory: which selected?
pls help me step by step i realy need this because a new set x3 cant flash???????????????????
Old 10-04-2010, 09:31   #2 (permalink)
Member: 277937
Thanks Meter: 48
Version from phone: 04.11
Version from file: 08.40
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8955(29-09-2010), 1.0.0.14639(29-09-2010)
Reading phone`s ID ...
SYSTEM ASIC ID: 000000010000022600000001020C192102034100 [RAPS2 ver: PA 4.x]
ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D
ROM ID: 67E82268F29CEA60
Custom loader not available for this ID !
Restarting phone ...
RAP Data :
EM0 ID: 00001040
EM1 ID: 00001030
PUBLIC ID: 10D0000F1C7B0E494BEC44656C680DA35E99E6BA
ASIC MODE ID: 00
SecondaryBoot: RAP3Gv40_2nd.fg [BB5] version: 8.41.0 revision: 2.0 size: 0x3B80
Supported RAP Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000
New Protocol is not supported for the current interface (UFS_USB V2.8 (c) SarasSoft 2007.).
Read Certificate failed.
Old 10-19-2010, 04:50   #3 (permalink)
VODAFONES's Avatar
Member: 747968
Sonork: 100.1621353
Thanks Meter: 444
anyone can help us... i hv some problems also ...
Old 10-19-2010, 05:33   #4 (permalink)
sharpgsm's Avatar
Member: 313652
Sonork: 100.1625717
Thanks Meter: 99
only turbo flasher is having large support for the loaders
if have use turbo bt mx key is more user friendly
Old 10-19-2010, 06:37   #5 (permalink)
Member: 686500
Thanks Meter: 12
for x3 atf is the best
Old 11-25-2010, 15:07   #6 (permalink)
foufou34's Avatar
Member: 695274
Thanks Meter: 814
the same problem for me..................X3 not supported
Old 11-25-2010, 18:21   #7 (permalink)
Member: 654510
Thanks Meter: 21
try this ....
select the path which ur products contains .....
ex : programfiles/nokia/pehonix/product/
Old 08-25-2011, 10:05   #8 (permalink)
Member: 1474383
Sonork: arslanqadir1
Thanks Meter: 3
Version from phone: 042.007
Version from file: 071.003
MXKEY Serial: [FT SCR2000 0] - C081564D
Driver: uhci:hub:UFS2XX, ver: 3.8.14.0 , NTMP ver: 2.8.14.0
Module ver: 1.0.0.17743(23-06-2011), Library ver: 1.0.0.11773(23-06-2011)
Reading Important data ...
Reading RPL backup ...
Reading Phone IDs ...
SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPU ver: 1.1]
ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
ROM ID: E693EF0DAC22615B
SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.10.0 revision: 3.0 size: 0x3B40
Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
Reading Secure Storage ...
Reading SIMLOCK data ...
Reading CERT data ...
CMT Data :
EM0 ID: 00000C35
EM1 ID: 00000C30
PUBLIC ID: 0A700119D8A403447A01F66E2317564D82A3CE46
ASIC MODE ID: 00
SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 9.50.0 revision: 3.0 size: 0x3A40
NewProtocol is not supported for current interface (UFS_USB V2.8 (c) SarasSoft 2007.).
NPC_DATA is empty.
SIMLOCK_DATA saved OK
SIMLOCK_KEY_DATA saved OK
WMDRM_PD_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
LOCK120_DATA saved OK
BB_DATA saved OK
WLAN_DATA saved OK
plz help i try on ufs and mx key but not ok this error show plz tell me the solution
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 13:21
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 22:36
Page generated in 0.22465 seconds with 9 queries
