03-17-2009, 04:36 | #1 (permalink) |
Freak Poster Join Date: Apr 2007
Member: 494019 Status: Offline Thanks Meter: 159 | Easy link hear here is all nokia repair soulation dircet link downlaod no need register free all gsm members. more updates cheek here :kedip: all antina switch 33xx pfo wayssss 33xx software ok pow sw off 1100 2300 charge wayss 1100 Car Prob solution 1100 charge1 1100 charge final 1100 flash light 1100 handsfree 1100 lay out 1100 not charging 1100 POWER BOTON 1100 ringer track 1100 sim main bord.rar 1100, 2300 charge 2 1100,2300 local mode 1100_20positi_20suply 1100_2300 truble shooting 1 1100_2300 truble shooting 2 1100_2300_mic 1100_car_problem2 1110 ic keys 1110 mic ways 1110-1600_20LCD_Light_problem 1110_0mic_ways2 1110_20local_20mode_20problem2 1110_1600 mice.1 1110_1600_0mic_ways.2 1110_1600_6030 charging ways 1110_1600_6030 not charging 1110_1600_audiofrom_conector 1110_6030_light_ic_replace_with_6610_light_ic 1110_loca_mod_problem.2 1600 1110 buzzer ways 1600 keypad2 1600 led 1600-1100 earpiece problem.3 1600-keypad sche 1600-_on off sw 1600_1110 6030 INSERT SIM CARD 1600__handsfree_mode 2100 3610 charge ways 2100 charge ways2 2100 CONTNUES CHARGING 2100 FAILED TO POWER ON. 2100 Mic ways 2100 sim 2100 truble shooting 1. 2100 truble shooting 2 2100complete jumper 2112 ringer_ways cdma 2600 insert sim card 2600 lcd ways. 2600 LOCALMOD 2600 NO CHARGE 2600 no charge WD 2600 ringer ways 2600 sim ways 2600-LCD.2 2600ringerfullways. 2650 NO LIGHT. 2650 truble shooting 1. 2650 truble shooting 2. 3100 6100 lcd ways 3100 6100 led. 3100 charge problem. 3100 destroyed antenna PAD solution. 3100 flash ic. 3100 insert sim 3100 key 5.if not work 3100 keypad jumper. 3100 key waysss. 3100 key waysss 2.rar 3100 localmode with battery solution. 3100 no lcd led light 3100 on_of switch 3100 pcb 3100_6100 ringer ways 3100_charge. 3100_duplexer. 3200 fm radio fault. 3200 power sivic. 3200 sim ic. 3200 truble shooting. 3200 truble shooting 1 3200 truble_shooting2 3200bord. 3200_KeyBoard. 3200_keyboarerror. 3210 charging problem 3210 no ringer 3210audio 3210charging1 3210chargig2 3210power. 3220 led. 3220 led problem.2 3220 led wayes.rar 3220 on off switch 3220 sim wayes. 3220-earpiece-mice-ringer 3220power swtich. 3220_20led_wayes. 3220_6020 insart sim card. 3220_6020 LCD Ways. 3220_camera_wayes. 3220_display ways 3220_display_light_parts. 3220_sim_wayes. 3230 bluetooth wayes. 3230 FLASH WAYES. 3230_20bluetooth_wayes 3230_20ear_solution 3230_20MIC_WAYES.rar 3230_FLASH_WAYES. 3230_SIM-MMC_WAYES 3250 Keypad IC jumper. 3250camra falt. 3250_no signal_restart 3310 dead phone. 3310 HANG.gif 3310 insert sim.rar 3310 NoDisplay.rar 3310 power switch way-B200. 3310 Repair Guide. 3310 restart. 3310 truble shooting. 3310copmlete jumper 3310speaker 3310_dead. 3310_reconnectcharger 3410_Reconnect_Charger. 3510 NO CHARGE. 3510 on off switch ways 3510i led ways 3510i lokal mod. 3510i mic ways 3510i positive track 3510i sim ways. 3510i_audio 3510i_charge_lines. 3510i_lcd.rar 3510i_lcd_ways. 3510led.2 3510no_ringing 3510_NO_CHARGE. 3530 and 3510 power switch broken track. 3590 led 3650 3660 camera ways 3650 joystick jumper 3650 keypad jumper 3650 repair audio 3650 trubble shooting 1 3650 trubble shooting 2. 3660 key problem. 5100 lcd wayss 5100 lcd waysss 5140 camera ways 5140. 5210 audio and vibra ways 5210 lcd ways 5210 ringer ways 5210audio 5210lcd. 5210led. 5210ringer 5210_insert_sim. 5500 Keypad IC Jumper 5500_displways 6030 AUDIO WAYES. 6030 EASY FLASH WAYES. 6030 LCD WAYES-2. 6030-power_wayes. 6100 audio faults 6100 buzzer wayss. 6100 KEYPAD FAULTS. 6100 KEYPAD WAYES. 6100 NETWORK 6100 rf block diragem. 6100 rf frequency plan 6100 rx signal path 6100 SIM CARD FAULTS 6100 SIM WAYES. 6100 tx signal path 6100--DEAD GENERAL INFO. 6100-CHARGING FAULTS 6100-FLASH FAULTS. 6100phone is jammed 6100_no_ringer2 6101 Local Mod Solution 6131_6133 Keypad IC Jumper 6170_7270 Keypad IC Jumper 6210 NETWORK REPAIRE 6210 on off 6210 ON OFF SWITCH 6210-ringer-fault. 6220 ıhf SPE- AND EARPİECE. 6220 spaekar buzzer. 6230 ACI WAYES 6230 BLUETOOTH INTERFACE 6230 CAMERA WAYES. 6230 CHARGE WAYS 6230 CHARGING WAYES 6230 COMPONENT LAYOUT1 6230 COMPONENT LAYOUT2. 6230 dead general info 6230 display light. 6230 flashing problem general info 6230 FM RADIO WAYES 6230 key and lcd led repair 6230 keypad. 6230 keypad wayes 6230 LED WAYES. 6230 light 6230 light problem1 6230 MMc 6230 MMC WAYES 6230 power sivicth. 6230 POWER WAYES 6230 pw sw flot UEM. 6230 RF INTERFACE 6230 SIM WAYES. 6230 Test Mode 6230i_camera 6230_buzar 6233 Sim IC jumper 6233_6234 Keypad IC Jumper 6233_6234_Keypa_Jumper 6255 -6255i-6246-6256i-sim wayes 6260 CAMERA J_.part1. 6260 CAMERA J_part2 6260 charge ways 6260 KEYPAD PROBLEM. 6260 key problem 6260 LCD solution. 6260 ringer wayes 6260 sim-mmc 6270 Keypad IC Jumper 6280 keypad ic jumper 6280_key_pad. 6280_on_off_ways switch 6280_on_off_ways_ShahJeE 6310 6310i on off 6310 6310i pow[1].sivitch 6310 SIM IC bridge 6310i charge ways 6310i lcd ways 6510 -8310 LCD 6510 -8310 LCD YOL. 6510audio. 6600 buzzer and spe. 6600 camera 6600 CHARGE WAYSS 6600 insert sim card 6600 key pad ic 6600 keypad ic jumper 6600 keypad light not working 6600 lcd. 6600 lcd led repair. 6600 lcd wayss. 6600 no net work. 6600 power sivicth ways 6600 power switch speakerpad. 6600mmccardproblem 6600_insert_sim_card 6600_keypad-1 6600_mic_soulation 6600_startup falid. 6600_white 6600_white_LCD 6610 audio fault 6610 charge faults 6610 dead faults. 6610 display fault 6610 extracting package failed. 6610 flash programming faults. 6610 illumination fault 6610 keypad wayes. 6610 phone jammed. 6610 signal fault 6610 sim card fault 6610-7210-7210i-lcd wayes. 6610_sim_repair 6630 keyboard wayes 6630 lcd wayes. 6630 mice-earepiece-ringer-wayes 6630 micro phone. 6630 no light solution 6630 power key solution 6630 RINGER WAYES 6630 Test 6630 Unlocking. 6630rap3g 6630_audio. 6630_bt_problim 6630_Cam_1. 6630_Cam_2. 6630_charge. 6630_lcd_ways 6630_Ringer_problam 6630_sim. 6630_Test Jit. 6630_Test Jit1. 6630_Test Jit2. 6650-7210-7250 LCD. 6670-7610 camera wayes 6670-7610 earpice wayes. 6670-7610 LCD. 6670-7610 power switch wayes 6670-7610 RINGER WAYES 6680 AMBIENT SENSER WAYES. 6680 BLUETOOTH WAYES 6680 CAMERA WAYES. 6680 FLASH LED WAYES. 6680 LCD WAYES. 6680 SDRAM WAYES 6820 charge ways. 6820 speakar ways 6820. 7200 sim ic1. 7200_sim_WAYS. 7210 Ring 7210_32006610sim_ways 7250i_3200_6610_7210_6610_light soulation 7610 buzzer WAYS 7610 camra. 7610 charging part 7610 display. 7610 display ic 7610 lcd repair 1. 7610 lcd repair 2 7610 MEMORY CARD CORRUPTED. 7610 power sivich 7610 sim. 7610 SIM WAYES 7610-6670 MIC WAYES. 7610_6600 memory jumper 8310 6510 keypad. 8310 buzzer repair. 8310 inset sim. 8310-6510-6500 sim 8800 Sim IC Jumper. 8910 flex solution. 8910 repair hints. 8910i_20lsd_light. bluetooth. e6_audio_prolim. E60 Keypad IC Jumper. e61 lcd ways e61 signal wayes e61 singel. e61joystick not working. e61_charge_ways e61_power_switch mmc ic shorting. n70 charge n70 charger wayes n70 insert sim. n70 keyboard wayes n70 key pad.rar n70 lcd. N70 LCD WAYES. n70 mice-earpiece-ringer n70 mmc wayes. n70 not charging soulation. n70 on off. n70 sim wayes. N70_N72 Keypad IC Jumper. N72 Antina Switch n73 charger wayes n73 IHF speaker_vibra wayes N73 Keypad IC Jumper. n73 mic_earpiece wayes. n73 power key wayes n73 sim wayes N80 Keypad IC Jumper N90_mic n91 charger wayes. N91 Keypad IC's Jumper. n91 power key wayes n91 vibra_ringer wayes network. NGAGE KEYPAD 1 NGAGE KEYPAD 2. NGAGE KEYPAD 3. Ngage qd sim ways click here for latest update always cheek here dont forget to thanks button |
The Following 15 Users Say Thank You to FIXXGSM For This Useful Post: |
12-07-2009, 09:44 | #2 (permalink) | |
Junior Member Join Date: Dec 2006
Member: 406662 Status: Offline Thanks Meter: 1 | the link is not working Quote:
The Following User Says Thank You to SRIRAAM For This Useful Post: |
03-05-2011, 11:22 | #4 (permalink) |
No Life Poster Join Date: May 2008 Location: gsm city
Member: 767786 Status: Offline Thanks Meter: 320 | can both of you guys read. these posts were done on 17-03-2009 & 7-12-2009 MORE THAN A YEAR AGO its definitely going to be old solutions & most probably invalid links use SEACRH button & you will find many working links with these old solutions or new ones |
The Following User Says Thank You to NeeMan For This Useful Post: |
:.all nokia repair soulation easy link here.: | ..::hotlovercool4::.. | Nokia Hardware & Hardware Repair | 270 | 01-19-2011 17:43 |
All N-Gage games Easy Link | soban | Nokia Multimedia | 9 | 12-18-2007 19:17 |
T208 PC Cable > PCB037LBEC/STD + Easy Link v2.01 1000%WORKS | lion108h | VLSI, Conexant, Skyworks and Old Models | 0 | 09-30-2005 08:03 |
problems with easy link for sgh a 800 | juliverena | VLSI, Conexant, Skyworks and Old Models | 1 | 05-25-2003 20:53 |
easy link+a800 | tommylcl | VLSI, Conexant, Skyworks and Old Models | 4 | 04-08-2003 06:46 |
