Old 09-26-2009, 07:36   #151 (permalink)
Member: 1127025
Thanks Meter: 12
Originally Posted by digitized View Post
check shorting in 6300...
1..remove this coil mark in (1)...if u want to check is pf is short,.....
2..remove this coil mark in (2)..if u want to check rf ic is short because rf ic also got +b volt from battery....
3..remove this coil mark in (3)..if u want to check blutooth ic is short because bluetooth ic also got +b volt from battery....
4..remove this coil mark in (4)..if u want to check the v.camdig maker ic ..this v.camdig maker ic got +b from batery....
5..remove this coil mark in (5)..if u want to check the light ic is short....
6..also check the memory card driver ic n3200 it also got +b it can be check by only removing this ic.....
7..at end remove retu and tahvo ic...
all the component which are mark in pink colur these all are coils these are place in series and +b of batery is gone throw them so if u remove the coil u not have to remove ic to check the shorting in pcb it save time and ur ic ....
dear sir plz tell me nok 3230 display light is not working i need help with vedio thank
The Following 2 Users Say Thank You to heera.singh For This Useful Post:
Old 09-26-2009, 07:39   #152 (permalink)
Member: 1127025
Thanks Meter: 12
please sir tell me 3230 nokia display light is not workingh send me with vedio
Old 09-26-2009, 18:50   #153 (permalink)
Member: 1127471
Thanks Meter: 6
Very nice ty
Old 09-27-2009, 18:23   #154 (permalink)
Member: 1127025
Thanks Meter: 12
n 1110 light
plz tell me n 1110 light how to on it is not working
Old 10-01-2009, 13:42   #155 (permalink)
Member: 1124250
Thanks Meter: 62
thanks for sharing..
The Following User Says Thank You to axxes For This Useful Post:
Old 10-01-2009, 16:42   #156 (permalink)
Member: 1129158
3110 lcd ok but display blank..... plz help me broth....
Old 10-09-2009, 04:07   #157 (permalink)
Member: 922090
Thanks Meter: 3
thanks a lot.i want the dead handsets repairing solution can you please send me that for all sets.my id is [email protected]
The Following User Says Thank You to deepoottan For This Useful Post:
Old 10-15-2009, 18:59   #158 (permalink)
Member: 959567
Thanks Meter: 3
Digitized that's all it's a great solution...Many2 thank u....
The Following User Says Thank You to Nonem77 For This Useful Post:
Old 10-16-2009, 22:11   #159 (permalink)
Member: 460522
Thanks Meter: 2
still dsnt work
check shorting in nokia 6670,7610.......
2...remove this coil mark in (2)..if u want to check the display light ic is short....
3..remove ic mark in (3)... this is memory card driver ic this also got +b from batery....remove it to check shoting is gone or not.......
4...remove this transistor ic mark in (4)...this is transistor ic for key pad light ....remove this if u want to check the shoting cause by this transistor....because this transistor got +b from batery......
5..remove this transistor ic mark in (5)...this ic make volt for lcd 2.5v (vlcd)....this ic got +b from batery ....remove this if u want to check the shoting cause by this transistor.....
6...remove boot ic mark in (6)..if u want to check shoting cause by boot ic if it is short replace it with new one......
7..remove ringer ic mark in (7) ....if u want to check shorting throug ringer ic is gone or not...
8.....remove this smps ic mark in (8)... to check the shoting cause by this ic.........this ic make v corea volt for upp...
9..at end remove uem to check shoting is gone or not.....
all the component which are mark in pink colur these all are coils and resistance these are place in series and +b of batery is gone throw them so if u remove the coil and resistance u not have to remove ic to check the shorting in pcb it save time and ur ic ....
digitized
hi
I have removed 1,2,3,4,5,7,8 I havnt remove 6 and i cant find 9 in the diagram.
Also still my phone dsnt work.This phone was dropped on water and i have cleaned and heated by sunlight, now its more than 6 month,Then i found this site and remove above i mentioned but still it dsnt work.I meant power cnt on.
pls help
The Following User Says Thank You to riya2000r2k For This Useful Post:
Old 10-17-2009, 07:05   #160 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
Originally Posted by riya2000r2k View Post
hi
pls help
no 9 is uem means power ic
check the pic .....
The Following 4 Users Say Thank You to digitized For This Useful Post:
Old 10-17-2009, 08:17   #161 (permalink)
siang8788's Avatar
Member: 205283
Thanks Meter: 80
n82 water damage,when put battery got red light automatic,solution?
Old 10-17-2009, 14:08   #162 (permalink)
Member: 1142118
i need for n95 shoting testpoint
The Following User Says Thank You to khaja mohideen For This Useful Post:
Old 11-05-2009, 07:45   #163 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
check shoting in nokia 2700c-2....
1..Remove this coil mark in (1)..if u want to check the light ic N2301 is short....
2..Remove N3200 ic mark in (2) ...this is memory card driver ic .remove it to check shoting is gone or not....
3..Remove this ic n6000 mark in (3)..this is blutooth & radio ic remove it to check shoting is gone or not because this ic also got +b volt from battery....
4..remove this coil mark in (4) ....if u want to check the shoting cause by handfree ic ...handfree ic got the +b.....
5..Remove this ic n1002 mark in (5)...if u want to check the pf N1002 this pf based on new tecknology... this this ic got +b from batery ic ... this ic work for network...
6..Remove ic N1001 mark in (6) ..if u want to check it ..this is rf ic based on new tecknology ...this ic got +b from batery ic ... this ic work for network...
at end remove betty and avilma ic to check shoting is gone or not........
..::digitized::..
The Following 17 Users Say Thank You to digitized For This Useful Post:
Old 11-09-2009, 15:01   #164 (permalink)
Member: 1092807
Sonork: histar
der,
iwant nokia cabel findar we'r link to downloading this software ,
tkx,
Old 11-09-2009, 15:13   #165 (permalink)
Member: 1092807
Sonork: histar
dear,,,,,,galaxyman nokia cable finder ver10.2 downloading this software ..........txs
Page generated in 0.26480 seconds with 10 queries
