Old 12-08-2009, 14:23   #181 (permalink)
Member: 460522
Thanks Meter: 2
nokia 6670
what to do if keypad some numbers dsnt work?
I have checked the number board by placing with another phone and it works
also a working phone number board i placed in this phone and same thing some numbers dsnt work
Tha means something wrong with motherboard
therefore how do i fix this problem
Thanks
Old 12-15-2009, 14:09   #182 (permalink)
Member: 257704
Thanks Meter: 12
Originally Posted by digitized View Post
check shorting in nokia dct4++ 2630.....
1..remove the pf n7700 mark in (1)...if u want to check is pf is short remove it and check shoting...if it is shot then replace it...
2..remove this coil mark in (2)..if u want to check the light ic is short....
3..remove ringer ic mark in (3)..if u want to check shoting remove it and check if shoting is gone replace it because ringer ic also got +b volt from battery....
4..remove this v.camdig ic n3301 mark in (4)..if u want to check the v.camdig maker ic ..this v.camdig maker ic got +b from batery....to make v,cam for camera.....
5..remove this ic n6000 bluetooth and fm ic mark in (5)..if u want to check the shoting cause by it remove it and check shoting because it got =b from batery....
6..at end check the power ic and reemove it to check shoting is there or not...
all the component which are mark in pink colur these all are coils these are place in series and +b of batery is gone throw them so if u remove the coil u not have to remove ic to check the shorting in pcb it save time and ur ic ....
in above number 6..at end check the power ic and reemove it to check shoting is there or not... what is shorting GSM repairs. Thank you
The Following User Says Thank You to ibn muhammad For This Useful Post:
Old 12-16-2009, 15:30   #183 (permalink)
Member: 900385
Sonork: 1234
Thanks Meter: 10
hi i have nokia 2626 after power on it hangs pliz help
Old 12-23-2009, 06:39   #184 (permalink)
Member: 604797
pls, i cant store captured picture on my n73. i need help
Old 12-23-2009, 22:07   #185 (permalink)
chochol's Avatar
Member: 86757
Thanks Meter: 12
Today I tried to exchanged PA from one phone to another. I use phone (with 100% good PA ) but after exchanging to second phone PA is short circuited. I used 515 Celsius to solder and it looks that I damaged it. Can anybody recommend which temperature to use for exchanging or which technique to use. THANKS
Old 12-25-2009, 18:49   #186 (permalink)
Member: 1190668
6235 hang any solution sir?
Old 12-26-2009, 06:16   #187 (permalink)
Member: 1178814
e1 coil is broken
can we able to replace the coil e1 and small battery is there ....
Old 12-27-2009, 04:03   #188 (permalink)
Member: 1192511
Sonork: 15582
Thanks Meter: 16
1100 full sort
hot uem.have any solution ?
Old 12-30-2009, 06:41   #189 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
Originally Posted by **************** View Post
1100 full sort
replace uem .....be carefull to replace it ,,it is glued....
Old 12-30-2009, 10:05   #190 (permalink)
snisar's Avatar
Member: 517952
Sonork: Nisar mongaM
Thanks Meter: 495
Hello Bro.
I have 6120c , Short on Little ....... not full short, Battery discharge immedeatly ?
Plz Help me......
anyway a Big Clap for this thread.
Old 01-03-2010, 09:48   #191 (permalink)
Member: 970764
Thanks Meter: 38
Originally Posted by al_imran_foru View Post
1112 slow speed sloution plz help me
change real time clock u r problem solve
Old 01-03-2010, 17:09   #192 (permalink)
Member: 721077
Thanks Meter: 9
Originally Posted by Bikas Das View Post
6630 offline mode plz. help me
chenge sim ic 100% ok
The Following User Says Thank You to F.A.Mobile For This Useful Post:
Old 01-04-2010, 21:32   #193 (permalink)
mccm's Avatar
Member: 173565
Thanks Meter: 71
one 6120 no corrosion,but its shorted to ground.
What are the capacitor to replace?
Old 01-05-2010, 10:17   #194 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
Originally Posted by snisar View Post
Hello Bro.
Plz Help me......
check shorting in nokia 6120c rm-243......
1..remove this coil mark in (1) l7510...if u want to check is pf n7520 is short,.....this pf is for 850/900mhz and for 1800/1900mhz...
2..remove these both coil mark in (2)..if u want to check rf ic is short because rf ic also got +b volt from battery....
3..remove this coil mark in (3) l7550 if u want to check the pf n7540 is shot ....this pf is for 1950mhz ...band...
4..remove this coil mark in (4) ..l7591 to check the ic n7541 which make controling volt for n7540....
5..remove this coil mark in (5) if u want to check the ic n7601 ...this ic is for network ....this ic got +b from batery through this coil ......
6....remove the memory card driver ic n3200 mark in (6) it also got +b it can be check by only removing this ic.....
7..remove this ic mark in (7) n2390.. this ic make v-core supply for rapido(cpu)...this also got +b from batery to make v-core voltage ... if this ic is damage then ur phone not boot in soft or manual....
8..remove n3300 ic mark in (8) ...it is vdig_cam maker ic which make vdig cam for camera ......remove this to check shoting because this ic got +b from batery......
9...remove n3320 ic mark in (9) ...it is vana_cam maker ic which make vana cam for camera ......remove this to check shoting because this ic got +b from batery......
10..remove this coil mark l3301 in (10)..if u want to check the shorting cause by flash light driver ic d3301 ....because this ic got +b from batery...
11.. remove this ic n2000 mark in (11)... this ic is for earphone spekers ...remove this ic to check shoting because this ic got +b from batery....
..at end remove bety and avilma power ic to check shoting is gone or not......
digitized...
The Following 21 Users Say Thank You to digitized For This Useful Post:
Old 01-06-2010, 11:19   #195 (permalink)
Member: 992629
Sonork: 100.1624926
Thanks Meter: 31
nokia 6500s short
what can i do?
Page generated in 0.24877 seconds with 10 queries
