Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Mark Forums Read |
![]() | #213 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2005 Location: ludhiana~india Age: 38
Member: 163833 Status: Offline Sonork: 100.1579554 Thanks Meter: 5,700 | |
The Following 3 Users Say Thank You to digitized For This Useful Post: |
![]() | #216 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2008 Location: LAGOS NIGERIA
Member: 773516 Status: Offline Sonork: 100.1583311 Thanks Meter: 69 | 6500c short pls pls help 6500c short need urgent phone work ok after changing screen battery low so i charge d battery with desktop i put d battery back phone now blink and off.i have test d flex with another phone work fine.pls need short urgent.thx in advance ![]() |
![]() | #219 (permalink) |
Member: 163833 Status: Offline Sonork: 100.1579554 Thanks Meter: 5,700 | check shorting in nokia 2330.... 1..remove this coil mark in (1)..if u want to check the light ic is short.... 2..remove this ic n3303 bluetooth and fm ic mark in (2)..if u want to check the shorting cause by it remove it and check shoting because it got +b from batery.... 3..remove this v.camdig ic n3301 mark in (3)..if u want to check the v.camdig maker ic ..this v.camdig maker ic got +b from batery....to make v,cam for camera..... 4..remove the pf n7700 if u want to check is pf is short remove it and check shoting...if it is shot then replace it... 5..at end check the power ic and remove it to check shorting is there or not... all the component which are mark in blue colur these all are coils these are place in series and +b of batery is gone throw them so if u remove the coil u not have to remove ic to check the shorting in pcb it save time and ur ic .... br. digitized |
The Following 14 Users Say Thank You to digitized For This Useful Post: |
![]() | #222 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2008 Location: punjab ,jalandher
Member: 672494 Status: Offline Thanks Meter: 109 | 5800 shorting hello sir i want ur help small can u give the diagram of 5800 : ; 5800 the set was fully short can u help me plz sir ![]() |
The Following User Says Thank You to laddimobile For This Useful Post: |
![]() | #225 (permalink) |
Member: 163833 Status: Offline Sonork: 100.1579554 Thanks Meter: 5,700 | check shorting in nokia 6500s rm-240...... 1..remove this coil mark in (1)...if u want to check is gsm pf n7520 is short,..... 2..remove these coils mark in (2) if u want to check the shoting of wcdma pf n7540.... 3..remove these coil mark in (3)..if u want to check rf ic n7505 is short because rf ic also got +b volt from battery.... 4..remove these all ic mark in (4)....all these ic make volt for camera ...all these ic got +b from batery... 5..remove this ic n3352 mark in (5)..if u want to check the shorting cause flash light driver ic ....because this ic got +b from batery.... 6..remove light ic mark in (6) ... to check the shoting cause by light ic or not.... 7..remove bluetooth module d6000 mark in (7 )... to check shoting ...because it got +b from batery..... 8..remove this ic n2401 mark in (8)... this ic work as keypad light ic and control the keypad light.... 9..remove this ic n4801 mark in (9) ...this ic make volt vsd for memory card... this ic got +b from betry.... at end remove avilma and betty ic to check shoting is gone or not.... all the component which are mark in pink colur these all are coils these are place in series and +b of batery is gone throw them so if u remove the coil u not have to remove ic to check the shorting in pcb it save time and ur ic .... wbr, digitized |
The Following 19 Users Say Thank You to digitized For This Useful Post: |
