Old 07-09-2010, 17:57   #256 (permalink)
Member: 1341738
Sonork: none
Thanks Meter: 2
please how to check nokia 7610s shoting if phone is water damage
Old 07-09-2010, 18:48   #257 (permalink)
rakib_sheak's Avatar
Member: 1201843
Thanks Meter: 487
Originally Posted by digitized View Post
check shorting in 6300...
1..remove this coil mark in (1)...if u want to check is pf is short,.....
2..remove this coil mark in (2)..if u want to check rf ic is short because rf ic also got +b volt from battery....
3..remove this coil mark in (3)..if u want to check blutooth ic is short because bluetooth ic also got +b volt from battery....
4..remove this coil mark in (4)..if u want to check the v.camdig maker ic ..this v.camdig maker ic got +b from batery....
5..remove this coil mark in (5)..if u want to check the light ic is short....
6..also check the memory card driver ic n3200 it also got +b it can be check by only removing this ic.....
7..at end remove retu and tahvo ic...
all the component which are mark in pink colur these all are coils these are place in series and +b of batery is gone throw them so if u remove the coil u not have to remove ic to check the shorting in pcb it save time and ur ic ....
bro
nokia e71............. 80% short
phone is ok please help
Old 07-18-2010, 06:42   #258 (permalink)
Member: 1335526
6300 lcd graphics ok but no light
Old 07-19-2010, 14:56   #259 (permalink)
CASTRANOVA's Avatar
Member: 593785
Thanks Meter: 102
try with this 3 kind of solution
DOWNLOAD : GSM MAGIC
The Following User Says Thank You to CASTRANOVA For This Useful Post:
Old 07-19-2010, 15:54   #260 (permalink)
Member: 1259782
i need one nokia E90 keypad solution
please any friend help me
Old 07-25-2010, 05:14   #261 (permalink)
Member: 1341738
Sonork: none
Thanks Meter: 2
Please send me the shorting image of nokia 5030
Old 07-27-2010, 10:08   #262 (permalink)
Member: 1352123
some body help me 7210c charging is not taking
Old 07-31-2010, 07:50   #263 (permalink)
Member: 1184182
Sonork: jigs krishna
Thanks Meter: 3
is porsible to 3110c calculator software install manualy. like call record.
give me positevely reply.
thanx in advance
Old 07-31-2010, 13:49   #264 (permalink)
Rise's Avatar
Member: 39022
Sonork: 1575244
Thanks Meter: 95
NOkia c5 short
any solution\
thanks advance
Old 09-03-2010, 22:31   #265 (permalink)
Member: 578919
it would be very good solution for all of member of this forum many thanks for kind solution by me eky junior thanks for all
Old 09-04-2010, 00:15   #266 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
Thanks Meter: 11,983
need x3 short solution .
Old 09-15-2010, 14:36   #267 (permalink)
3OG
3OG's Avatar
Member: 230904
Thanks Meter: 41
6760s manual if any ...
Old 09-21-2010, 08:48   #268 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
check shorting in nokia 2690.....rm-635...
1..Remove this ic n1002 mark in (1)...if u want to check the pf N1002 this pf based on new tecknology... this this ic got +b from batery ic ... this ic work for network..but it has very few chance to get short...
2..Remove ic N1001 mark in (2) ..if u want to check it ..this is rf ic based on new tecknology ...this ic got +b from batery ic ... this ic work for network...but it has very few chance to get short....
3..Remove this coil mark in (3)..if u want to check the light ic N2301 is short....
4..remove this coil mark in (4) ..if u want check the handfree ic n2000 is short...
5..Remove N3200 ic mark in (5) ...this is memory card driver ic .remove it to check shoting is gone or not....
6...Remove this ic n6001 mark in (6)..this is blutooth & radio ic remove it to check shoting is gone or not because this ic also got +b volt from battery....
7...remove these two capcitor mark in (7) to check shorting these capcitor got shorting due to water damage ...,
at end remove betty and avilma ic to check shoting is gone or not........
all the component which are mark in pink colur these all are coils and resistance these are place in series and +b of batery is gone throw them so if u remove the coil and resistance u not have to remove ic to check the shorting in pcb it save time and ur ic ....
The Following 8 Users Say Thank You to digitized For This Useful Post:
Old 09-23-2010, 13:05   #269 (permalink)
aliyousafzai's Avatar
Member: 1358184
Sonork: 100.1616912
Thanks Meter: 615
i have nokia 1112 no signal plz help me
Old 09-27-2010, 12:06   #270 (permalink)
Member: 1341582
Pls give me test diagrammm to n81 plz
bat shorted
plz sir
Page generated in 0.17133 seconds with 10 queries
