Old 11-07-2010, 10:57   #286 (permalink)
Member: 540345
Thanks Meter: 175
nokia shorted solution exe.......
[IMG]http://4.bp.********.com/_KJjqutwf-28/TMh1YXOQDVI/AAAAAAAACIk/wRT_Ffx_d3U/s320/vfdb.png[/IMG]
NOKIASHOTSolution.rar - 4shared.com - online file sharing and storage - download
The Following 4 Users Say Thank You to asifawan For This Useful Post:
Old 11-09-2010, 02:00   #287 (permalink)
Member: 619511
Thanks Meter: 53
i need e71 shoot and e63 shot
thank
Old 11-13-2010, 03:16   #288 (permalink)
Member: 1432402
hello fren can u provide me that all guide me
Originally Posted by digitized View Post
check shoting in 5200 and 5300.....
1..remove this coil mark in (1)...if u want to check is pf is short,.....
2..remove this coil mark in (2)..if u want to check rf ic is short because rf ic also got +b volt from battery....
3..remove this coil mark in (3)..if u want to check blutooth ic is short because bluetooth ic also got +b volt from battery....
4..remove this ic ..if u want to check the v.camdig maker ic ..this v.camdig maker ic got +b from batery....
5..remove this coil mark in (5)..if u want to check the light ic is short....
6..also check the memory card driver ic n3200 it also got +b it can be check by only removing this ic.....
7..at end remove retu and tahvo ic...
all the component which are mark in pink colur these all are coils these are place in series and +b of batery is gone throw them so if u remove the coil u not have to remove ic to check the shorting in pcb it save time and ur ic ....
digitized
[email protected]
Old 12-01-2010, 13:11   #289 (permalink)
Member: 1134507
Sonork: 100.1607956
Thanks Meter: 201
need help
i need help for display of sonyerricasson c905 . what i do no display and all ready chang strip what i do more for it?
Old 12-15-2010, 22:08   #290 (permalink)
Member: 1119881
bro, in generaly what mean of shoting ? I mean how to knw that phone is shot ?
Old 12-23-2010, 09:15   #291 (permalink)
Member: 533423
Sonork: 8897204000
Thanks Meter: 4
hi,somebody help me to flash rm-78 nokia 6280 mobile
The Following User Says Thank You to abdul ahad For This Useful Post:
Old 01-03-2011, 06:16   #292 (permalink)
Member: 1468649
Thanks Meter: 2
Thumbs up thanks a lot
somebody help me i need 6300 latest flash file its urgent
Old 01-05-2011, 12:57   #293 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
check shorting in nokia c3...and some usefull info about nokia new ics...
1...remove the n2301 ic mark in (1)...it is the light ic ..it got +b ....(this ic is same as nokia 1600 light ic.)
2...remove the coil l2814 mark in (2)...to check the shorting cause by n2801 ic..its the ringer ic ...(this ic is same as nokia 1600 ringer ic.)
3...remove the ic n2000 mark in (3)...it is headset ic...this ic got +b ..(this ic is same as nokia 7210 headset ic.)
4...remove the ic n6300 mark in (4)...it is bluetooth,fm,wifi ic...this ic got +b....
5...remove the ic n7500 mark in (5)...it is pf in built with rf ic....this ic also got +b ...
6...at end remove ic n2001 (loviisa)...it is power ic of the handset ...
all the component which are mark in pink colur these all are coils and resistance these are place in series and +b of batery is gone throw them so if u remove the coil u not have to remove ic to check the shorting in pcb it save time and ur ic ....
changes made by nokia in this handset...
1..nokia use the old light ic as use in nokia 1600...
2..nokia use the old ringer ic as use in nokia 1600...
3..in this handset the nokia change the memorycard ic ..this ic does not got +b ..it is directly connected with cpu(juno)..and power ic loviisa made volt (vamp2) for it..
4..volt for camera also make by loviisa(power)..
5..speaker,mic & vibration connected with juno(cpu)..
6..sim is also connected with juno(cpu)
nokia introduce two new ic .loviisa and juno ....
function handel by loviisa and some usefull info about it ...
1..n2201 (loviisa) is the power ic of the handset..
2..loviisa make the volt for whole ics in the pcb ex,
vcore & vmem for cpu and flash..
vsim for sim..
vcam for camera..
vamp2 for memorycard..
volt for rf parts..
3..charging and usb interface is also connected with loviisa ...
4..power on/off key is also connected with it..
function handel by juno (brodcomm) and some usefull info about it ...
1..juno is is the cpu of the handset but it also controls the other function of the handset...
2..juno is directly connected with sim ,memorycard,camera ic ,speaker ,mic,vibration ,etc...
3..lcd and keypad are also connected with juno..
4..rf section is also connected with juno...
happy new year to all forum members..
br,
digitized
The Following 10 Users Say Thank You to digitized For This Useful Post:
Old 01-05-2011, 15:03   #294 (permalink)
262068's Avatar
Member: 689645
Thanks Meter: 14
sir thnks for this sectioin i have a nokia 3110c it s have not full sorted its have geve some resistence on both batterry conector not full continuty. from this resion set working ok but its battery go round in two days what shoud i do for it.
Old 01-06-2011, 09:17   #295 (permalink)
Member: 378867
e71 btemp
e71 btemp r 47k one side ground other side connection need
Old 01-06-2011, 09:19   #296 (permalink)
Member: 378867
plsss any one help me
(problem charging not supported
Old 01-07-2011, 08:01   #297 (permalink)
Member: 1081011
Sonork: 100.1594100
Thanks Meter: 463
Other Side Connect To BSI Line...........................
Old 01-08-2011, 06:11   #298 (permalink)
Member: 1081011
Sonork: 100.1594100
Thanks Meter: 463
Other Side Connect To BSI LIne..............................
Old 01-08-2011, 08:03   #299 (permalink)
Member: 1346194
Sonork: mr.andy143
pls help me how to check r tras nokia 2700c not charging and suggestion me for repair..... voltage 1 vat show only..
ur @ndy
Old 01-11-2011, 18:56   #300 (permalink)
Member: 1243993
Sonork: +6287846666699
Thanks Meter: 12
cek retu suport resistor...is work for me...gbu
Page generated in 0.23229 seconds with 10 queries
