Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Mark Forums Read |
![]() | #316 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2010 Location: emrites
Member: 1427645 Status: Offline Sonork: sohail---- Thanks Meter: 27 | 1..remove this coil mark in (1)...if u want to check is pf is short,..... 2..remove this coil mark in (2)..if u want to check rf ic is short because rf ic also got +b volt from battery.... 3..remove this coil mark in (3)..if u want to check blutooth ic is short because bluetooth ic also got +b volt from battery.... 4..remove this ic ..if u want to check the v.camdig maker ic ..this v.camdig maker ic got +b from batery.... 5..remove this coil mark in (5)..if u want to check the light ic is short.... 6..also check the memory card driver ic n3200 it also got +b it can be check by only removing this ic..... 7..at end remove retu and tahvo ic... all the component which are mark in pink colur these all are coils these are place in series and +b of batery is gone throw them so if u remove the coil u not have to remove ic to check the shorting in pcb it save time and ur ic .... Download nokia short solutiom by mr.benua3.rar from Sendspace.com - send big files the easy way like ,,thnx |
![]() | #318 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2005 Location: Italy Age: 42
Member: 164613 Status: Offline Thanks Meter: 11 | The best way to find a short- FOR ALL PHONE MODELS- you MUST have a power supply first. 1. put the voltage to 0 on the power supply and check it is set on the high current (usually 2A), if available 2. connect the phone board, without lcd and flexes 3. rotate slowly the voltage regulator to add voltage, the current consumption will increase, and the board will ger hot 4. check by hand, by fingers WHERE it gets hot 5. if you cant see precisely where is the hot ic, but you find the hot region, tahe the brush wet with your cleaning solution- alcohol or whatever you have and met on that region. The solution will boil on the hottest component. |
![]() | #319 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2005 Location: ludhiana~india Age: 38
Member: 163833 Status: Offline Sonork: 100.1579554 Thanks Meter: 5,700 | check shorting in nokia x2-00 rm-618....and some usefull info about nokia new ics... 1...remove the coil l2401 mark in (1)...to check the shorting cause by the light ic....(this ic is same as nokia 1600 light ic.) 2...remove the coil l2820 mark in (2)...to check the shorting cause by n2802 ic..its the ringer ic ...(this ic is same as nokia 1600 ringer ic.) 3...remove the coil l2814 mark in (3)...to check the shorting cause by n2801 ic..its the ringer ic ...(this ic is same as nokia 1600 ringer ic.) 4...remove the coil l1410 mark in (4)...to check the shorting cause by n1400 ic..it is flash light driver ic... 5...remove the ic n2000 mark in (5)...it is headset ic...this ic got +b.. 6...remove the ic n7500 mark in (6)...it is pf in built with rf ic....this ic also got +b ... 7...at end remove ic n2201 (loviisa)...it is power ic of the handset ... all the component which are mark in pink colur these all are coils and resistance these are place in series and +b of batery is gone throw them so if u remove the coil u not have to remove ic to check the shorting in pcb it save time and ur ic .... changes made by nokia in this handset... 1..nokia use the old light ic as use in nokia 1600... 2..nokia use the old ringer ic as use in nokia 1600... 3..in this handset the nokia change the memory card ic ..this ic does not got +b ..it is directly connected with cpu(juno)..and power ic loviisa made volt (vamp2) for it.. 4..volt for camera also make by loviisa(power).. 5..speaker,mic & vibration connected with juno(cpu).. 6..sim is also connected with juno(cpu) nokia introduce two new ic .loviisa and juno .... function handel by loviisa and some usefull info about it ... 1..n2201 (loviisa) is the power ic of the handset.. 2..loviisa make the volt for whole ics in the pcb ex, vcore & vmem for cpu and flash.. vsim for sim.. vcam for camera.. vamp2 for memorycard.. volt for rf parts.. 3..charging and usb interface is also connected with loviisa ... 4..power on/off key is also connected with it.. function handel by juno (brodcomm) and some usefull info about it ... 1..juno is is the cpu of the handset but it also controls the other function of the handset... 2..juno is directly connected with sim ,memorycard,camera ic ,speaker ,mic,vibration ,etc... 3..lcd and keypad are also connected with juno.. 4..rf section is also connected with juno... br, digitized |
The Following 8 Users Say Thank You to digitized For This Useful Post: |
![]() | #322 (permalink) |
Junior Member Join Date: Mar 2011
Member: 1540033 Status: Offline Sonork: syedbaazigar Thanks Meter: 1 | hello bro... may *** bless u ....n ur the king of sorting... pls help me i have problem in Nokia 5233 Headset connector damaged.... send me with pic 5233 headset connector ways... to [email protected] thanks in advance... |
![]() | #324 (permalink) |
Junior Member ![]() ![]() Join Date: Apr 2011 Age: 33
Member: 1549891 Status: Offline Sonork: ippu khan Thanks Meter: 0 | nokia 5310 all solution Hotfile.com: One click file hosting: Nokia5310XpressMusicFullSolution.rar Last edited by ippu khan; 04-23-2011 at 08:36. |
![]() | #325 (permalink) |
Member: 1540033 Status: Offline Sonork: syedbaazigar Thanks Meter: 1 | nice work keep it up.... plz i need help i have problem in 5230 headset connector damaged in board ... can u plz give me its ways... [email protected] thanx in advance |
![]() | #329 (permalink) | |
Crazy Poster ![]() ![]() ![]() Join Date: Apr 2007 Location: in your heart Age: 41
Member: 497268 Status: Offline Thanks Meter: 6 | Quote:
