06-02-2011, 11:53 | #331 (permalink) |
Freak Poster Join Date: Jan 2011
Member: 1488757 Status: Offline Thanks Meter: 98 | ``````````To check shoting in nokia 3230 first remove display board in which display or camera is place or then check shoting is gone or not,........................ 1....remove this COIL mark in (1) if u want to check the shoting of pf .......remove the coil and ur shoting is gone then there is shoting in ur pf ....... 2...remove this coil mark in (2)..if u want to check the light ic is short.... 3...remove boot ic mark in (3)..if u want to check shoting cause by boot ic if it is short replace it with new one...... 4...remove this resistance mark in (4)....if u want to check shoting cause by infrared .....because infrared got +b through this resistance...... 5...remove this smps ic mark in (5)... to check the shoting cause by this ic.........this ic make v corea volt for upp... 6...remove ringer ic mark in (6)... to check the shoting cause by ringer ic...... 7...remove ic n233 mark in (7).... this ic make regulator volt for display and for camera....this ic got +b from batery......remove it to check shoting is gone or not....... 8...remove ic n234 mark in (8) ... this is vcam maker ic this ic make volt for camera.... .this ic got +b from batery......remove it to check shoting is gone or not....... 9...remove n130 ic mark in (9)... this is memory card driver ic this also got +b from batery....remove it to check shoting is gone or not....... 10...at end remove power ic to check shoting is gone or not....... all the component which are mark in pink colur these all are coils and resistance these are place in series and +b of batery is gone throw them so if u remove the coil u not have to remove ic to check the shorting in pcb it save time and ur ic .... |
07-17-2011, 09:53 | #336 (permalink) |
Freak Poster Join Date: Dec 2006 Location: India
Member: 407037 Status: Offline Thanks Meter: 15 | easy way to dead short board .without remove component friends any mother board dead short don't remove any component. easy way to find out which component short. take fully charged original nokia battery to conect battery conectors fast contact and remove 5 to 10 times with in 5 seconds gap.after that fast abserve in mother board which component heat form . many times i conform this method. mostly shorting components [pfs and power and charging ics electolight capasitors. |
08-07-2011, 07:22 | #339 (permalink) |
Junior Member Join Date: Aug 2011
Member: 1627141 Status: Offline Thanks Meter: 2 | I'm facing a problem with my N73. Key number 2 doesn't work and I have cleaned the connections many times. Any suggestions? |
The Following User Says Thank You to tonito-vodafone For This Useful Post: |
08-14-2011, 12:02 | #342 (permalink) |
Freak Poster Join Date: May 2009 Location: india (mp) Age: 41
Member: 1034081 Status: Offline Thanks Meter: 59 | MXKEY Serial: [MxKey HTI FLASHER INTERFACE 6] - Using device: HTI BOX, FW ver: 00.07 Driver: uhci:hub:hub:ccgp:HTIBUS, ver: 3.4.7.0 , NTMP ver: 2.6.0.0 Module ver: 1.0.0.17743(23-06-2011), Library ver: 1.0.0.11773(23-06-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 0210011698127F569DB05D1DCE3B1C5D00693E06 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 Storage0: 0089 8981 - 0000 6A21 [Intel NU48F256,256 Mbits] type: FLASH,NOR, asic:CMT Storage content: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS is blank/erased. TransmissionMode: DDR&TX2 Processing MCU file: rm237__07.30.mcusw [BB5,BB5 ALGORITHM] size: 14.49 MB Supported Ids: 0103192101001101, 010C192101001101 Erase skipped. Flash programming ... Error while programming [00] at 0x00000400, Result: 0000 Task failed at (0800001C)!!! Last RX buffer: C9 7F FB FF Phone Emulation failed, please report to the author ! this error plz help >> rajgsm_dnp |
08-24-2011, 08:16 | #344 (permalink) |
Freak Poster Join Date: May 2010 Location: with~predators Age: 39
Member: 1312914 Status: Offline Thanks Meter: 111 | check this page already posted use search button always... http://forum.gsmhosting.com/vbb/f148...2/index12.html |
