04-23-2008, 14:32 | #1 (permalink) |
Freak Poster Join Date: Apr 2006 Location: Punjab, Pakistan Age: 38
Member: 264520 Status: Offline Thanks Meter: 61 | " Error in Network Connection " 1100 I've a Nokia 1100. Whe I mak call or any other person try to call me phoe show this error "Error in Network Connection" plz give me solution to remove this fault which area is faulted... thnx |
04-23-2008, 16:15 | #2 (permalink) |
No Life Poster Join Date: Jul 2005 Location: ludhiana~india Age: 38
Member: 163833 Status: Offline Sonork: 100.1579554 Thanks Meter: 5,700 | 1.brthr check first fitiing is proper or not or clean it.... 2.replace antena switch... 3.if not solve reheat or replace pf.. 4.if then not solve also change rx filter bet ween antena switch and hagar... try and post result good luck..digitized http://www.techiesrealm.com/ |
04-23-2008, 16:34 | #3 (permalink) |
No Life Poster Join Date: Apr 2004 Age: 49
Member: 61294 Status: Offline Thanks Meter: 49 | This is a network problem from your subscriber. 1. your environment can cause this Problem. 2. your building can affect this problem, if you are making calls between tall buildings. Hardware solutions. 1. try replacing the battery and try making call. For Example - borrow battery from your friend to try this. 2. try cleaning your mobile phone antenna. 3. if it continued - call customer services of your network provider from another phone. bestman |
04-23-2008, 16:37 | #4 (permalink) |
Member: 264520 Status: Offline Thanks Meter: 61 | dear thnx to reply... I'll try... but can any body tell me surly, in which area TX or RX is faulted in "Error in Network Connection "???? When I try to make call mostly done good... but when any other person try to call me mostly NOT done.... I'm waiting for ur good responce.. thn*** |
04-23-2008, 17:09 | #6 (permalink) |
Freak Poster Join Date: Dec 2007 Location: Pakistan
Member: 641971 Status: Offline Thanks Meter: 34 | error in connection Dear Brothers This Is Not Service Rpoblem,this In Hand Set Problem I Cant Found Any Proper Solution,i Got This From Antena Switch Not 100 %,but 60% From There Thnx Post Ur Result |
1200 error in network connection | AS_ADNAN440 | Nokia Hardware & Hardware Repair | 6 | 05-24-2009 11:44 |
3110c showing error in network connection | RATHNAMOBILESS | Nokia Hardware & Hardware Repair | 9 | 01-28-2009 11:45 |
" Error in Network Connection " 1100 | asrar | Nokia Hardware & Hardware Repair | 2 | 04-23-2008 16:43 |
