04-06-2010, 20:20 | #1 (permalink) |
Junior Member Join Date: Apr 2010
Member: 1278450 Status: Offline Thanks Meter: 1 | Explain the reasons for some of the most crashes Bb5 Hard ware on the basis of readin CMT 1st Boot Err: Bad Resp RAPx in the first line only without the rest of the readings Means that the fixtures did not read the device will be final and the cause of this problem or RETU TAHVO or RAP3G you and I'm putting them on the basis of this arrangement is easier to work on The worse and that there is any circuiting of the device was the cause. In case it has been read by the device, but there is an error in reading specific readings to be the center of one of the following readings: CMT Err cause of the problem of the NEC or RAP3G Almimory flash (ie, not C combo flash) or sometimes rare HELEN processor, or sometimes called OMAP, but are accessed in the name of the software, HELEN HELEN Err cause of the problem of HELEN processor, or as it was mentioned by APE Err cause of the problem of de Isaiah Flash Memory kombu large as possible and the problem of Isaiah APE regulator is that you Ptzim nutrition efforts Algihaz runs as possible, but a white screen does not accept the written statement should de APE: ERR In some cases, failure comes as follows CMT: 000000000000FFFFFFFFFFFF Or CMT: FFFFFFFFFFFFFFFFFFFFFFFF The problem of de Isaiah flash Alsgierp In some cases, come to recognize the failure and HELEN RGP3 but does not recognize the CMT and APE the problem is not de Brcissor OMAP HELEN mean but be of RPG3 Of course there is a common problem and known possible solution, but going through a rare case of a problem Mismatch as possible there will be amendments to the licensure and possible de Alpaor be mostly survivors in Mie Mieh, but in the case tried on the Alturnado your hands the same letter and resolution in Albrcissor RGP3 There is another case Algihaz possible landing on the soft down should fully working ul setting But what Algihaz runs and never try to read your hand Alpaor Supply is like lighting and ergonomics, but not Mvic Data on the screen be the problem de Rama Of course, after you select the reading is dealing with the components on the order in question or by personal desire of the existing maintenance and the first to review components necessary to heat or change is needed, and I wish that I brought you put new information, informative, and *** is over success and thank you |
BB5 HARD WARE TRIK BY Mr.Benua3 | jubjang | Nokia Hardware & Hardware Repair | 2 | 01-06-2009 07:48 |
This Is The Reason For You Use Rocker Dongle | NOKIA127 | Rocker Dongle (By Legija) | 7 | 07-28-2008 02:17 |
What is the reason for this error | khawar | UST Pro II | 0 | 02-26-2007 18:51 |
