Old 06-03-2001, 15:56   #1 (permalink)
Member: 4274
Thanks Meter: 18
Post Z500 duplexer (3210)
does this device or component is sensitive to heat? and if yes, up to what extent of temp. does this one can hold on...
The Following User Says Thank You to ambot For This Useful Post:
Old 06-03-2001, 21:17   #2 (permalink)
Bph&co's Avatar
Member: 1024
Thanks Meter: 5,510
Post
Hi,
Absolutely this is the most sensitive to the heat part of the whole RF unit.
As less as possible temperature.
Also important rule - don't put too much copper on siver or gold plated RF parts.
Best Regards
The Following User Says Thank You to Bph&co For This Useful Post:
Old 06-03-2001, 22:02   #3 (permalink)
Member: 4274
Thanks Meter: 18
Post
so this Z500 is the possible problem on my phone(3210) for not having a signal? Because i have tried to heat up this one and also put a little more soldering lead on its terminal...
Old 06-04-2001, 20:32   #4 (permalink)
Bph&co's Avatar
Member: 1024
Thanks Meter: 5,510
Post
Hi,
Common problem with the bad/no reception in 3210 is Cobba chip. As you know this chip contain all ADC/DAC converters needed for convert I/Q analog signals to digital and back. Bad connection of the balls under the chip will cause also breaking of audio path.
I saw some new versions have a glue a side of Cobba to prevent breaking the balls.
To check is that a problem - twist the board (reasonable angle !) and check for change in the RSSI value change( WinTesla tests )
Best Regards
Old 06-05-2001, 14:18   #5 (permalink)
Member: 4274
Thanks Meter: 18
Cool
the cobba in this unit had a glue at all sides, as i inspected with a microscope all sides with a glue were all intact and i tried to **** again with a hot air with the use of hakko850 but the unit still the same (no signal)... by the way i have accidentally put a soldering lead on the copper pad of the Z500 because i'm trying to resolder the contacts, so, does this could affect the component function? and also sorry i don't have any idea yet with regards to wintesla... if it's okey with you, can you teach me how to use it and what are the materials do i need when i have to use the wintesla? i do have a service manual...
Old 06-05-2001, 20:14   #6 (permalink)
Bph&co's Avatar
Member: 1024
Thanks Meter: 5,510
Post
Hi,
Y2K home page have good explanation how to use WinTesla - please check his profile for the link.
Best Regards
Old 06-05-2001, 21:04   #7 (permalink)
Member: 4274
Thanks Meter: 18
Post
thanks... i found his homepage...
lg u8120 pa and duplexer,needed for buy GOODNESS LG 0 12-19-2006 20:24
Sony duplex software? Lajos Sony Ericsson Media, RingTones, Games 0 01-12-2005 12:31
6100 duplex tgsm Nokia Hardware & Hardware Repair 1 11-19-2004 11:33
1100 duplexer,how to test without it? fiZ Nokia Hardware & Hardware Repair 1 11-02-2004 12:27
Flasher updatet with duplex MBUS for FAID calc without Dejan jan Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 21 02-17-2002 16:29
Page generated in 0.21544 seconds with 10 queries
