08-05-2002, 21:12 | #1 (permalink) |
No Life Poster Join Date: May 2001
Member: 4675 Status: Offline Thanks Meter: 7 | freezing 8250 thanks |
08-05-2002, 21:21 | #2 (permalink) | |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | Re: freezing 8250 Eurek8888, Good ,, it is real problem reason 8250 hung , because pad for CPU become rusty ! if you remove CPU, and clean epoxy , then you can see it rusty at L1, M1, N1 pin, or N7 N8 N9,,,,,, no others way. only remove CPU, and clean rusty , then put new CPU , that's it Quote:
08-06-2002, 16:23 | #3 (permalink) |
No Life Poster Join Date: Sep 2001 Location: Country of "TIHS"
Member: 6349 Status: Offline Thanks Meter: 6 | Willy is right usually CPU or Flash is not good connected to pcb. Sometime we can solve this Hang 82 series with ADD some Hard Foam between CPU or Flash IC and Housing... Let the Housing or CPU push the FOAM...if not hang again....hurry up sell it to someone hehehehe... Coz usually its only can use 1 or few week...after that it will Hang Again.... This Solution is just for CPU or Flash with GLUE...if without glue...just Change it... |
8250-freezing solution freeee!! | F C | Nokia Hardware & Hardware Repair | 1 | 06-03-2002 14:27 |
8250 reset/freeze/auto turn off | TheEckoMan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 05-24-2002 05:22 |
8250-- freezing after cs- removal | F C | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 16 | 04-16-2002 15:46 |
nokia 8250 - hangs -freezes | PTR999 | Nokia Hardware & Hardware Repair | 0 | 03-04-2002 10:42 |
8250 intermittent freezing | ACE_UK | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-23-2001 22:02 |
