Old 07-09-2010, 09:41   #1 (permalink)
Member: 900385
Sonork: 1234
Thanks Meter: 10
nokia 1202
hi i have several nokia 1202 all insert sim problem,some one to help me
The Following User Says Thank You to bomet For This Useful Post:
Old 07-09-2010, 09:51   #2 (permalink)
Registered User
Member: 692221
Thanks Meter: 19
Command Master
NASAGSM.DOWNLOAD
Old 07-09-2010, 22:14   #3 (permalink)
Registered User
Member: 1087294
Thanks Meter: 252
hi bro its not enough to make sim ic jumper for insert sim fault first check sim jack voltage if correct voltage then no need to make ic jumper clean charging jack and resold or change charging jack 95% for this type of model 1200 1650 2630 etc if sim jack voltages showing short then make ic jumper and the middle pin of battery connector is most important for insert sim so check bsi line
i think you understand try and post result if not solved i m here
The Following 2 Users Say Thank You to bruightmobile For This Useful Post:
Page generated in 0.16619 seconds with 9 queries
