help 3310 in tornado it power on but with batterie it not power on help 3310 with cable in tornado it power on and all is okbut with batterie it not power on |
hi Quote:
ccont change-------------------------------- |
1 Attachment(s) Quote:
check attachment...you make no:2 wire no:3 and replace ccont..ok...good luck...regards |
Phone will power on by correct resistor installed for "BSI" / "BTEMP" it might be "powerup" by give "logic-high" to Btemp that pin to switch on the phone ! so, you might need to check the resistor for BSI and Btemp, then go chech the power on switch both side , is it give VB+ ? and when press power switch, then it must be connect to GND ! Willy |
