07-10-2009, 00:06 | #1 (permalink) |
Insane Poster Join Date: Jul 2007 Location: paraguay
Member: 557956 Status: Offline Thanks Meter: 5 | help, 6120c say, sim card not valid |
07-10-2009, 21:02 | #6 (permalink) |
Member: 557956 Status: Offline Thanks Meter: 5 | jaf info JAF version 1.98.63 Detected PKEY: 9000D60D Card life counter: 99.99% P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30107 JAF DCT4/BB5 LOADERS DIR: C:\Archivos de programa\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Archivos de programa\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Archivos de programa\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Archivos de programa\ODEON\JAF\Flash3\ USB Cable Driver version: 7.1.16.0 Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 05.11 21-04-08 RM-243 (c) Nokia PCI version: RFIC version: 17141715 DSP version: 06w41pb_08w08.0.1_rm243 APE SW Core version: 05.11 APE Variant version: rofs_version_inforofx_version_info APE Test version: rm243_ENO_x_2007wk24v0.01 Retu version: 15 Tahvo version: 22 APE HW version: 256 APE ADSP SW version: 256 Production serial number: 0 Product code: Module code: Basic production code: Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: 356253012316084 IMEI spare to net: 3A 65 52 03 21 13 06 08 IMEI SV to net: 33 65 52 03 21 13 06 48 F0 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 0000000000000000 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Searching for saved ini... Checking for file C:\Archivos de programa\ODEON\JAF\JAF_RM-243.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: Searching for JAF saved location of ini... Checking path: C:\Archivos de programa\Nokia\Phoenix\Products\RM-243\ Searching for default location of ini... Checking path: C:\Archivos de programa\Archivos comunes\Nokia\DataPackage\Products\RM-243\ Scanning ini files... Searching for default location of ini... Checking path: C:\Archivos de programa\Archivos comunes\Nokia\DataPackage\Products\RM-243\ FILES SET FOR FLASHING: MCU Flash file: C:\Archivos de programa\Archivos comunes\Nokia\DataPackage\Products\RM-243\rm243_ENO_x_2007wk24v0.01.fpsx PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! info self test |
07-11-2009, 04:04 | #9 (permalink) |
No Life Poster Join Date: Sep 2007 Location: :::::::EMIRATES:::::::
Member: 591669 Status: Offline Sonork: 110011 Thanks Meter: 687 | CONFIG KEY: 0000000000000000 PROVIDER KEY: 0000000000000000 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 problem this one you need write rpl; use sx4 service and writr pm you have backup? writ in rpl not solve calculate in rpl in server |
07-11-2009, 04:34 | #10 (permalink) |
Freak Poster Join Date: Aug 2008 Location: vietnam Age: 54
Member: 830301 Status: Offline Sonork: heocon Thanks Meter: 46 | your phonre have been locked cuz it damaged sim data , do a sim data repair will be good and fix your prob , get this soft from the forum " BB5 unlocker by lorci " it has simlock data repair ... |
07-11-2009, 21:33 | #13 (permalink) |
Member: 557956 Status: Offline Thanks Meter: 5 | jaleelkuttikkar, ay try to conect to sx4, pat not conect tis server, any idea log jaf Detected PKEY: 900241C1 Card life counter: 75.03% P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30107 JAF DCT4/BB5 LOADERS DIR: C:\Archivos de programa\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Archivos de programa\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Archivos de programa\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Archivos de programa\ODEON\JAF\Flash3\ USB Cable Driver version: 7.1.16.0 Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 05.11 21-04-08 RM-243 (c) Nokia PCI version: RFIC version: 17141715 DSP version: 06w41pb_08w08.0.1_rm243 APE SW Core version: 05.11 APE Variant version: rofs_version_inforofx_version_info APE Test version: rm243_ENO_x_2007wk24v0.01 Retu version: 15 Tahvo version: 22 APE HW version: 256 APE ADSP SW version: 256 Production serial number: 0 Product code: Module code: Basic production code: Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: 356253012316084 IMEI spare to net: 3A 65 52 03 21 13 06 08 IMEI SV to net: 33 65 52 03 21 13 06 48 F0 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 0000000000000000 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Searching for saved ini... Checking for file C:\Archivos de programa\ODEON\JAF\JAF_RM-243.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: Searching for JAF saved location of ini... Checking path: C:\Archivos de programa\Nokia\Phoenix\Products\RM-243\ Searching for default location of ini... Checking path: C:\Archivos de programa\Archivos comunes\Nokia\DataPackage\Products\RM-243\ Scanning ini files... Searching for default location of ini... Checking path: C:\Archivos de programa\Archivos comunes\Nokia\DataPackage\Products\RM-243\ FILES SET FOR FLASHING: MCU Flash file: C:\Archivos de programa\Archivos comunes\Nokia\DataPackage\Products\RM-243\rm243_ENO_x_2007wk24v0.01.fpsx PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! Checking for local SX card... Trying to use SX4 server... Server say: t|O[|@ Login... Detected P-KEY: 900241C1 Server say: PKEY p ka;/ Connecting to phone... Error sending data from server step1... |
sim card not valid on 6120c | msantar | Nokia Base Band 5 ( BB-5 ) | 7 | 07-29-2009 18:28 |
6120c sim card not valid after write pm | mega4life | Nokia Base Band 5 ( BB-5 ) | 2 | 05-10-2009 17:45 |
Phone Says SIM CARD NOT VALID | tamillan2006 | Phone Unlocking Codes & Maps | 4 | 04-08-2007 18:34 |
