help 6300 stop flash last moment :eek::rolleyes:my 6300 blue side light only then i flash it set ok but after few minite set show same problem blue light only then i have try to flash again but not complet last moment it stop plzzzzzzzzzzz help me.:eek::mad: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Driver: usbuhci:usbhub:UFS2XX, ver: 1.6.20.0 , NTMP ver: 1.6.20.1 Module ver: 1.0.0.17841(12-07-2011), Library ver: 1.0.0.11875(12-07-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 2C800109F4FC6C569FDA30CA9EDE1B8D9273E845 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 Storage0: 00EC 2208 - 0000 6921 [Samsung K8F5615ETM,256 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9 TransmissionMode: DDR&TX2 Processing MCU file: rm217__07.30.mcusw [BB5,BB5 ALGORITHM] size: 14.50 MB Supported Ids: 0103192101001101, 010C192101001101 Storing certificate [NPC, VARIANT, R&D] ...OK Erase size: 16.37 MB CMT FLASH,NOR area [00000000-000006BF] CMT FLASH,NOR area [000006C0-0001FFFF] CMT FLASH,NOR area [00020000-0007FFFF] CMT FLASH,NOR area [00080000-000DFFFF] CMT FLASH,NOR area [00100000-001FFFFF] CMT FLASH,NOR area [00200000-0031FFFF] CMT FLASH,NOR area [00320000-0105FFFF] CMT FLASH,NOR area [01060000-01067FFF] CMT FLASH,NOR area [01068000-0107FFFF] erased in 11.953 s Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 7F7E6491 [RAP Certificate 52 v1] sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent CMT PMM_CONF block sent CMT SBIF_CONF block sent Programming completed in 7 min 20.656 s Processing PPM file: rm217__07.30.ppm_c [BB5,BB5 ALGORITHM] size: 4.51 MB Supported Ids: 0103192101001101, 010C192101001101 Erase size: 5.50 MB CMT FLASH,NOR area [01080000-015FFFFF] erased in 13.422 s Flash programming ... Programming completed in 2 min 24.093 s Processing CNT file: rm217__07.30.image_c_tr [BB5,BB5 ALGORITHM] page size: 64 K size: 3.50 MB Supported Ids: 0103192101001101, 010C192101001101 Erase size: 9.87 MB CMT FLASH,NOR area [01600000-01FDFFFF] erased in 11.234 s Flash programming ... Programming completed in 1 min 43.484 s Total time for flashing process(boot+erase+write) was 12 min 16.343 s |
first deep clean d pcb then check . if same reflow or reball flash ic. u may also resold two rest points near flash ic then check.( search forum for image) |
