help me to identify the faulty ic in 7610-logs posted i have a white screen problem 7610.during flashing an error as below. 1st Boot Ok, WD2, UPP: 1081 Fl0: 0x00000000-0x00FFFFFF,00EC22F8,Sam K8S2815ET Fl1: 0x02000000-0x02FFFFFF,00EC22F8,Sam K8S2815ET Algorithm: w3_amd_b.fia Algorithm Ok, MSID: 84FDD99BEC99CC45B0D36504F7 Decoded MSID: 3E4EBAF7-00591CB4-A9000000 Encoded FAID: B6A18826-242D3023-581C47D1 Erasing: 0x00000000-0x0000FFFF ... Erasing Error: 10, at: 0x00000000-0x0000FFFF, 940207, Time: 00:00 i compared faulty 7610 flash log with a working 7610 log "1st Boot Ok, WD2, UPP: 1081 Fl0: 0x00000000-0x00FFFFFF,00EC22F8,Sam K8S2815ET Fl1: 0x02000000-0x02FFFFFF,00EC22F8,Sam K8S2815ET Fl2: 0x04000000-0x047FFFFF,00EC22FA,Sam K8S6415ET Algorithm: w3_amd_b.fia, Ver: 4.49.0 Algorithm Ok, MSID: 845BE6ADDD5FF01ADCDCA4E68A Decoded MSID: 3E4EBAF7-00871652-A9000000 Encoded FAID: AF2485C0-D3D5A664-EAC5F62A Area1: 0x00000000-0x0000FFFF Erased, Time: 00:00 Area2: 0x00010000-0x00FFFFFF Erased, Time: 02:37 Area3: 0x02000000-0x029FFFFF Erased, Time: 01:37 Area4: 0x02FC0000-0x02FEFFFF Erased, Time: 00:01 MCU Flashing Completed, Time: 04:58 Area1: 0x00000000-0x0000FFFF Erased, Time: 00:00 Area2: 0x02B00000-0x02D9FFFF Erased, Time: 00:25 PPM Flashing Completed, Time: 00:30 Flashing Completed, Rebooting Mobile"""""" from above comparison,i understood that flash area 3 not shown. Fl2: 0x04000000-0x047FFFFF,00EC22FA,Sam K8S6415ET i saw only two flash ic's d462,d460 in 7610.so which ic is flash area3? help me |
1 Attachment(s) help me which ic for FL0 AND FL1?(D460 OR D462) WHICH IC FOR FL2?(D460 OR D462) I THINK IN MY SET FL2 IS COMPLAINT. PCB LAYOUT ATTACHED-HELP ME |
ACCORDING TO UR SCHEMATIC THE UPPER FLASH IC IS FL2.NK 7610 HAS TWO DIFFERENT BOARD IF UR BOARD IS OLD THEN UPPER IS FL2 IF NEW LAY OUT THEN LOWER FLASH IC IS FL2.HOW CAN U IDENTIFY IS IT NEW OR OLD IF IT CONSIST SMALL IC BETWEEN THE UPP & FLASH IC THEN IT IS NEW PCB LAYOUT .IF NOT THEN IT IS OLD.HOPE U WILL UNDERSTAN. |
Flashi ic's info Quote:
BR Omairbutt786 |
Getting MCU ID MCU ID: 0x1081 FLASH ID0: DDFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: EEFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.01 Done! Phone Restarted... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE INI file .ini is missing. Continue searching for second ini type... Changing flashing settings... FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE706420.C1 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51PE706420.02 CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,French,German (Euro A) MCU: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE706420.C1 Booting phone... MCU ID: 0x1081 BOOT file: C:\Program Files\ODEON\JAF\Flash\w3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x10D8 Boot is ready... FLASH ID0: DDFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: EEFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Flash ID is 0xDDFE00EC Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7F10; Loader chk: 4 Loader is ready... P-key nokia module version 01.01 MSID: 848C13FB455E8CFD6CB5E5D72E MSID decoded: 3E4EBAF700172C1AA9000000 FAID: 1C4FE26F7E9F18D6FA088C8C Operation took 0 minutes 26 seconds... Erasing... Found 4 interval(s) to erase Erasing area: 00000000 - 0000FFFF... Erasing area: 00010000 - 00FFFFFF... Erasing area: 02000000 - 0287FFFF... Erasing area: 02FC0000 - 02FEFFFF... Operation took 2 minutes 54 seconds... Writing... Perm. Data Restore OK Operation took 3 minutes 16 seconds... Restarting MCU... PPM: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51PE706420.02 Booting phone... MCU ID: 0x1081 BOOT file: C:\Program Files\ODEON\JAF\Flash\w3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x10D8 Boot is ready... FLASH ID0: DDFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: EEFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Flash ID is 0xDDFE00EC Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7F10; Loader chk: 4 Loader is ready... P-key nokia module version 01.01 MSID: 848C13FB455E8CFD6CB5E5D72E MSID decoded: 3E4EBAF700172C1AA9000000 FAID: 1C4FE26F7E9F18D6FA088C8C Operation took 0 minutes 26 seconds... Erasing PPM... Found 2 interval(s) to erase Erasing area: 00000000 - 0000FFFF... Erasing area: 02A00000 - 02C9FFFF... Operation took 0 minutes 19 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 21 seconds... Restarting MCU... Flashing Done! Operation took 7 minutes 50 seconds... After flash processing... Waiting for phone to boot... Failed! Aborting! Init phone communication... Failed!!!........PHONE WAS DEAD.AFTER FLASHING ITS ONLY WHITE IN DISPLAY. ANY SOLUTION PLS. |
use erase fia files and flash.... write pm thats all......... if posssible save .rpl WBR... |
5 pin glass ic i think that 5ping glass ic between upp and flash is bad. and must change.if you find any jumper for it i need too. |
