Help me Nokia 6030 Phone Restricted Help me Nokia 6030 Phone Restricted i full Flash and Write Pm help me what i do ? |
use hwk set full ui then check problem still then check imei and another sim card use :) |
Phone Type: RM-74 (Nokia 6030) SW Version: V 5.11 30-05-06 RM-74 (c) Nokia. Imei plain: 35663200400088-1 Imei OTP: 35663200400088 Product Code: 0524937 Cellular System: GSM ASIC ID: 0x2031, type: 2 Ppm Id: G Language Pack: English,French,German,Spanish,Arabic,Urdu,Farsi Imei net: 35663200400088 Version: SIMLOCK SERVER VERSION 58 Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
i am also change many sim card problem not salved |
try flash latest verion and then unlock mx key |
br. first set eres 2nd flash 3rd write pm 4rd unlock good luck .br |
did u try to unlock this phone if u already tried than it will be a hardware problem |
try this 1st full erase 2nd full flash 3rd write pm 4rth unlock cheq if problem same problem in hardware |
i can do alll when i write Pm some sec is not write... |
w/s |
change sim ic ........................................ |
br . first. re hot cpu 2nd . good pm thanxxxxxxxxxx |
