Old 01-04-2008, 17:14   #1 (permalink)
sajidmirza's Avatar
Member: 256461
Sonork: 100.1608049
Thanks Meter: 90
nokia 6600 flashing problem
my 6600 handset is dead when connected to jaf it shows following log
Getting MCU ID
MCU ID: 0x1081
FLASH ID0: 01007E26 -> AMD Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
FLASH ID1: 01007E26 -> AMD Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10
FLASH ID2: 01007E26 -> AMD Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10
FLASH ID3: 01007E26 -> AMD Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 10
First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
P-key nokia module version 01.00
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
INI file .ini is missing. Continue searching for second ini type...
Changing flashing settings...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\NHL-10\NHL105530.C1
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\NHL-10\NHL105530.34
Languages in ppm: English,Philipinnes (APAC2/Philippines)
MCU: C:\Program Files\Nokia\Phoenix\Products\NHL-10\NHL105530.C1
Booting phone...
Phone didn't answer to request flash routine!
Causes:
1. UPP damaged -> replace UPP
MCU ID: 0xEEEE
This MCU ID is not supported in chosen flash file...
Error booting phone...
does any body have some ideas,pls share,
thanx.
Old 01-04-2008, 17:21   #2 (permalink)
Member: 396638
Thanks Meter: 6
Try erasing flash then use UFSx for flashing 5.27 version.
REGARDS!
Old 01-04-2008, 17:51   #3 (permalink)
sopnil's Avatar
Member: 528679
Thanks Meter: 268
Try With Ufs And Bt Disable First Then Flash
Old 01-21-2008, 20:05   #4 (permalink)
Member: 369369
Thanks Meter: 15
pls can any one help me to flash 6600 when i try to flash with ufs is say platform 6 erro . 0000000
0000000 pls what can i do
nokia 6600 flashing problem geminipt UFS2 + UFS3-Tornadoflasher 13 06-07-2008 14:33
Nokia 6600 Flash Problem Jaypc WD2 & APE (Symbian Phones) 7 05-22-2006 14:26
nokia 6600 flashing problem zata222 n-Box 3 07-24-2005 12:28
Nokia 6600 flashing problem Help! .::Moby World::. WD2 & APE (Symbian Phones) 0 04-03-2005 16:42
Page generated in 0.14746 seconds with 9 queries
