05-14-2012, 13:03 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: P A K I S T A N(+923149818013) Age: 33
Member: 326871 Status: Offline Sonork: down2 sky.up 2 the earth Thanks Meter: 636 | Help Mee :( with C3-00. |
05-14-2012, 13:58 | #2 (permalink) |
Member: 326871 Status: Offline Sonork: down2 sky.up 2 the earth Thanks Meter: 636 | Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.01, (Apr 29 2012 16:16:15, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C0000*** HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32 Initializing security card... Card Serial Number: D1000*** Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.09v PASSED MCU Voltage 3.30v PASSED Core Voltage 1.81v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 4.99v PASSED Box VPP disabled VPP Voltage 0.00v PASSED Internal Box VPP Enabled VPP Voltage 5.01v PASSED Box VPP disabled VPP Voltage 0.02v PASSED External Box VPP Enabled VPP Voltage 0.00v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 97 Avaiable Physical Memory: 866.212MB Avaiable Virtual Memory: 1.426GB Avaiable Pagefile: 1.956GB Initializing FBUS... All initialized - Ready to work Setting factory defaults of: Factory set full [Nokia C3-00 USB Phonet]: Port opened OK! [Nokia C3-00 USB Phonet]: Port opened OK! Phone not detected at USB -> Timeout, no any compatible USB device detected. Factory set failed -> Server not accepted issued factory set command Setting factory defaults of: Factory set full [Nokia C3-00 USB Phonet]: Port opened OK! [Nokia C3-00 USB Phonet]: Port opened OK! Factory defaults set OK Processing pre flash tasks... Pre flash tasks finished, continuing... Processing rm614__08.63.mcusw (CMT)... Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! New ROM Detected CMT_SYSTEM_ASIC_ID: 000000000000000022000509200C0000 CMT_EM_ASIC_ID: 00005361 CMT_PUBLIC_ID: 0000000000EC7A86F450BAC279BADE7F8FA8895D CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 1B0D74C532CA1C6133940C740E8C786E CMT_BOOT_ROM_CRC: DE56D582 CMT_SECURE_ROM_CRC: BDDE7A3A CMT Ready! rm614__08.63.mcusw, Type: Flash Image, Algo: BB5, XSR 1.6 Searching for BootCode: DualLine 32Bit BCM21351_usb2nd.fg, Type: 2nd Boot Loader, Rev: 513.11.48.0, Algo: BB5 Using NEW BB5 FLASHING PROTOCOL Transmission Mode Requested: Control USB, Accepted: Control USB Processing Flash Image Failed -> Failed to get CMT Configuration Failed to Process all Image files -> Failed to process rm614__08.63.mcusw Processing pre flash tasks... Pre flash tasks finished, continuing... Processing rm614__08.63.mcusw (CMT)... Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! New ROM Detected CMT_SYSTEM_ASIC_ID: 000000000000000022000509200C0000 CMT_EM_ASIC_ID: 00005361 CMT_PUBLIC_ID: 0000000000EC7A86F450BAC279BADE7F8FA8895D CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 1B0D74C532CA1C6133940C740E8C786E CMT_BOOT_ROM_CRC: DE56D582 CMT_SECURE_ROM_CRC: BDDE7A3A CMT Ready! rm614__08.63.mcusw, Type: Flash Image, Algo: BB5, XSR 1.6 Searching for BootCode: DualLine 32Bit BCM21351_usb2nd.fg, Type: 2nd Boot Loader, Rev: 513.11.48.0, Algo: BB5 Using NEW BB5 FLASHING PROTOCOL Transmission Mode Requested: Control USB, Accepted: Control USB FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC003000000431, Samsung, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0030 (Samsung), Size: 128MBytes, VPP: Not Supported BCM21351_XSR16_usbalg.fg, Type: Algorithm, Rev: 513.11.48.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Transmission Mode Requested: Bulk USB, Accepted: Bulk USB Box TX2 Data Pin set to: Service Pin 3 Waiting for FUR Client become avaiable... [Nokia USB Flashing Generic]: Port opened OK! FUR Avaiable! Adding FUR Client (CMT, State: Ready)... Failed to add FUR Client -> FUR-USB Handshake Not Accepted Processing Flash Image Failed -> Failed to Initialize FUR Protocol Failed to Process all Image files -> Failed to process rm614__08.63.mcusw Processing pre flash tasks... Pre flash tasks finished, continuing... Processing rm614__08.63.mcusw (CMT)... Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! New ROM Detected CMT_SYSTEM_ASIC_ID: 000000000000000022000509200C0000 CMT_EM_ASIC_ID: 00005361 CMT_PUBLIC_ID: 0000000000EC7A86F450BAC279BADE7F8FA8895D CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 1B0D74C532CA1C6133940C740E8C786E CMT_BOOT_ROM_CRC: DE56D582 CMT_SECURE_ROM_CRC: BDDE7A3A CMT Ready! rm614__08.63.mcusw, Type: Flash Image, Algo: BB5, XSR 1.6 Searching for BootCode: DualLine 32Bit BCM21351_usb2nd.fg, Type: 2nd Boot Loader, Rev: 513.11.48.0, Algo: BB5 Using NEW BB5 FLASHING PROTOCOL Transmission Mode Requested: Control USB, Accepted: Control USB FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC003000000431, Samsung, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0030 (Samsung), Size: 128MBytes, VPP: Not Supported BCM21351_XSR16_usbalg.fg, Type: Algorithm, Rev: 513.11.48.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Transmission Mode Requested: Bulk USB, Accepted: Bulk USB Box TX2 Data Pin set to: Service Pin 3 Waiting for FUR Client become avaiable... [Nokia USB Flashing Generic]: Port opened OK! FUR Avaiable! Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Overriding VPP Setting, USB can't use VPP Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 697F747788AD72E77DB3BC8DFEC0C28DA22F16D8 Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00000000-0x0001FFFF, ONENAND EraseArea[0,CMT]: 0x00020000-0x000203FF, ONENAND EraseArea[0,CMT]: 0x00060000-0x012FFFFF, ONENAND EraseArea[0,CMT]: 0x01300000-0x01DFFFFF, ONENAND EraseArea[0,CMT]: 0x02600000-0x029FFFFF, ONENAND Erase Partition (CMT) Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 0.328s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT KEYS Certificate... Writing CMT ADA Certificate... Writing CMT PRIMAPP Certificate... Writing CMT RAP3NAND Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT UPDAPP Certificate... Writing CMT MCUSW Certificate... Writing CMT MCUSW1 Certificate... Writing CMT GENIO_INIT Certificate... Writing CMT ISA+DYNSW Certificate... Programming Status OK! All blocks written OK! Time taken 5.928s Flashing Speed: 39478.78 kBit/S Processing rm614__08.63.mcusw (APE)... Processing rm614__08.63.ppm_i2 (CMT)... rm614__08.63.ppm_i2, Type: Flash Image, Algo: BB5, XSR 1.6 PAPUBKEYS Hash for CMT: 697F747788AD72E77DB3BC8DFEC0C28DA22F16D8 Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x01E00000-0x025FFFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.47s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 1.61s Flashing Speed: 44181.05 kBit/S Processing rm614__08.63.ppm_i2 (APE)... Processing rm614__08.63.image_i2_0597583 (CMT)... rm614__08.63.image_i2_0597583, Type: Flash Image, Algo: BB5, XSR 1.6 PAPUBKEYS Hash for CMT: 697F747788AD72E77DB3BC8DFEC0C28DA22F16D8 Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x02A00000-0x0753FFFF, ONENAND Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 1.76s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 2.917s Flashing Speed: 40646.57 kBit/S Processing rm614__08.63.image_i2_0597583 (APE)... Restarting MCU... All images processed OK! Processing post flash tasks... Setting Factory Defaults... Phone not detected at USB -> Timeout, no any compatible USB device detected. Phone not detected at USB -> Timeout, no any compatible USB device detected. Phone not detected at USB -> Timeout, no any compatible USB device detected. [Nokia C3-00 USB Phonet]: Port opened OK! [Nokia C3-00 USB Phonet]: Port opened OK! [Nokia C3-00 USB Phonet]: Port opened OK! [Nokia C3-00 USB Phonet]: Port opened OK! [Nokia C3-00 USB Phonet]: Port opened OK! Factory defaults OK Reading info... [Nokia C3-00 USB Phonet]: Port opened OK! MCU Version V 08.63 MCU Date 25-03-11 Product RM-614 (Nokia C3-00) Manufacturer (c) Nokia IMEI 3579020416965** Mastercode 5146577656 IMEI Spare 3A750902149656** IMEI SV 337509021496565F2000000 PPM V 08.63, 25-03-11, RM-614, (c) Nokia , I2 CNT Content: i2_0597583, V 08.63, 25-03-11, RM-614, (c) Nokia PSN 010C05EAY Product Code 0594156 Module Code 0204418 Basic Product Code 059D7N6 PSD 0000000000000000 LPSN 0 WLAN MAC D4C1FCD7EF4B HW 1008 RFIC 9 LCD SEIKO BT 4217-v529 Simlock Server SIMLOCK SERVER Simlock Key 2440700000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! [Nokia C3-00 USB Phonet]: Port opened OK! Selftests to proceed: 17 Passed ST_SIM_LOCK_TEST Passed ST_SECURITY_TEST Passed ST_PWR_KEY_TEST Passed ST_LCD_TEST Passed ST_LPRF_AUDIO_LINES_TEST Passed ST_LPRF_IF_TEST Passed ST_KEYBOARD_STUCK_TEST Passed ST_CAMERA_IF_TEST Passed ST_RADIO_TEST Passed ST_BT_WAKEUP_TEST Passed ST_WLAN_TEST Passed ST_CHIPSET_API_PMU_TEST Passed ST_CHIPSET_API_RFPA_TEST Passed ST_SLEEP_CLOCK_FREQ_TEST Passed ST_HOOKINT_TEST Failed ST_PWB_TEMP_TEST Failed ST_BTEMP_TEST Selftests done, Tests total: 17, Tests passed: 15, Tests not passed: 2 [Nokia C3-00 USB Phonet]: Port opened OK! [Nokia C3-00 USB Phonet]: Port opened OK! Test mode set [Nokia C3-00 USB Phonet]: Port opened OK! [Nokia C3-00 USB Phonet]: Port opened OK! Phone not detected at USB -> Timeout, no any compatible USB device detected. Failed to set Normal Mode -> Mode not accepted Flashing and self test also = C3 battery empty |
05-14-2012, 19:24 | #7 (permalink) | |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | Quote:
not all test pass !! reball or replace PMU/LOVIISA (N2201 / marked in pic) then check . also post here d result | |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
