Old 03-31-2009, 08:39   #1 (permalink)
ashok_kumar459's Avatar
Member: 202500
Thanks Meter: 234
n72 flashing ok on with cable/ battery not powering on
n72 flashing ok factory ok format ok local/test mode ok powering on with cable . with battery dead charing no used latest file again need to flash each time powering with cable. after rmoving dead......file used verson is latest tried both jaf/ufs
The Following User Says Thank You to ashok_kumar459 For This Useful Post:
Old 03-31-2009, 09:33   #2 (permalink)
FEATURE GSM™'s Avatar
Member: 276151
Sonork: 100.1577032
Thanks Meter: 234
yes bro fast you tri charge is ok or no if charge is ok then tri phone on/off line if charge is not ok then you tri power ic thanks
Old 03-31-2009, 18:50   #3 (permalink)
Member: 202500
Thanks Meter: 234
No charging . Dead please tel power ic is tavao please post image.............
Old 08-24-2010, 06:29   #4 (permalink)
Member: 664954
Thanks Meter: 12
Old 08-24-2010, 06:37   #5 (permalink)
kiran84's Avatar
Member: 504441
Thanks Meter: 29
DEAR 1st U CHECK THAT MOBILE IS CHARGING OR NOT,IF MOBILE IS CHARGING THEN PROBLEM IN ON/OFF WAYS....
IF MOBILE IS NOT CHARGE THEN 1st U CHECK THE CHARGING WAY IS OK OR NOT.
IF UR MOBILE POWERING ON CABLE ITS MEANS PROBLEM IN ON/OFF WAYS..
CHECK ITAND REPLY......GOODLUCK.........
N70 power on with ufs, with battery not power on krishnaaruna Nokia Hardware & Hardware Repair 17 03-02-2010 08:50
Sagem my230v after unlock with smti does not power on dsimka SMTi 1 04-15-2009 20:18
Nokia 1600 with sim does not power on! xela09 Nokia Digital Core Technology 4 ( DCT-4 ) 4 12-26-2006 13:21
Strange problem with 6101 phone! swtichin on with cable but not with battery??? ReyTech Nokia Hardware & Hardware Repair 0 08-01-2006 14:06
a55 flashing ok with freia, but not power on? luis035 E-Gold Based Phones 3 08-14-2004 09:18
Page generated in 0.17652 seconds with 9 queries
