05-25-2003, 00:54 | #1 (permalink) |
Junior Member Join Date: May 2003
Member: 28791 Status: Offline Thanks Meter: 0 | help nokia 6210 network i flashed phone repaled pa ,as .ccont , hager , cobba hopless case any can help me to found real solution to this probelm thanks, _______________ [GLOW=darkred]Moved from Hardware Repair section[/GLOW] Last edited by bop_gsm; 05-25-2003 at 17:21. |
05-25-2003, 16:37 | #4 (permalink) |
Freak Poster Join Date: Jun 2001 Location: Romania Age: 53
Member: 4875 Status: Offline Thanks Meter: 9 | check the conector for external antena ... remove the conector to see if he is the problem ... and if is ok with that check the diplexer ... and to be shoure that is a hardware problem and not a software problem ... >>> ... flash the phone like that : first with dejan software start to flash the phone with a full flash file ... after the erase procedure was completed disconect the phone ... so you have a full erased flash ... after that start the flashing with a flash that contains only MCU and PPM ( get from Gengheraenga site ) ... this procedure must be finished ... erase and write ... now you have a phone with no eeprom content ... and on display " Contact Service " ... the good part is that in the eeprom field you have no entry for any settings ... now use the any program ( Knok or other ) that restor all the factory setting and set the FAID and the IMEI ... and you have a phone with all the original factory setting and other network settings just ok ... I use this procedure many times and it is working for shure ... just try ... it could be your solution ... best regards , alianu ... |
help nokia 6210s keypad. | rangan_kumar | Nokia Hardware & Hardware Repair | 8 | 11-15-2012 10:27 |
Nokia 6210 network problem | spvaka | Nokia Hardware & Hardware Repair | 9 | 05-19-2012 15:34 |
help nokia 6210 navigator locked vodafone Portugal | pchop6t9 | YESSIM | 0 | 12-16-2008 22:24 |
Help! Nokia 6288 network unlock! | ching4ever | Phone Unlocking Codes & Maps | 4 | 12-11-2006 13:28 |
help! Nokia 6610 network unlock from T-zone? | iceox | Phone Unlocking Codes & Maps | 0 | 10-25-2003 05:00 |
