HELP!!! NOKIA 6310i speaker LOW SOUND my nokia 6310i has a mal funcion that when im talking to someone, the soudn is very low and i've put it in the maximum level and still wont give any good results!! tell me how can i fix this problem :) :( |
6310 speaker Try to replace the speaker. You can use the speaker out of most nokia's. If you do not have a spare speaker take your old one out ang brush the Diaphram with a soft brush and remove all lose matter, :D |
it still doing with a low sound a friend of mine has replaced with a speaker of a 3310 and it still with a very low sound!!!!! this kind of problem is not normal, is it????? thanks for replaying so fast!!! ;) |
I would still try another speaker. Check front cover to make sure holes not blocked. One other thing to check is that the board contacts are not dirty. After that you could have big probs. Could be one of a few things on board. |
Well as U performed the essential check , U still can reset it to factory settings. Any thing more will need to experience and tools, and I preffer U to take the phn. to a service center beter than U'r friend :) |
nokia 6310i speaker way |
