HELP nokia 6500c fake charging only!!! HI, if anybody have a fake charging solution please share to us, maybe i'm not the only one who encounter this problem but many.. The problem is it indicates chagring but not totally charge the battery it cannot full the battery, i check also flex inside and it looks okey, i also chage the battery but still cannot fully charge the battery... if somebady got this charging ways or picture i would be thankful for you. BR, Richello Baring |
Problem Solved! Okey i just repaired the charging problem a while ago and it's working fine now...:D i just made a jumper with it after i was able to trace the possitive (+) ways from USB to flex connector to main board. and now i works fine and it can totally stored energy to the battery! but sorry i do not have image to upload becase i don't have a camera. |
please upload i need this jumper please share :) |
Why make jumper? Simple it`s well known fault with 6500c, just change AV flex and ur phone will be 120% ok. This part is available on market long time ago. BR Janar |
1 Attachment(s) Quote:
BR Janar |
d2400 wr is it pls the clear image |
this is bool**** , this is not hardware problem , nokia 6500c want charge if you don't use only original charger. problem solved ONLY WITH ANOTHER ORIGINAL CHARGER |
Mr. Quote:
Pls help for: 'charging not supported'. much appreciated. |
Hi. Also pls help: LG U990 'insert battery' when charging the phone. Tks a lots. |
for charging not supported change batt temp resistor whit the same size |
batt temp capacitor or change AVILMA goodluck |
Hi Mr. Quote:
Tks a lot, would laod the diagram for me show the Batt temp resistor and compasitor. we are learners tks you very much. |
charging ways as alternative solution. 1 Attachment(s) This is the image i share to all of you which i manage to troubleshoot fake charging...:D press thanks button if you like it... |
problem solved Ribon is bad. Measured resistance betwen pin1 usb and pins123 b2b connector is about 90 ohm! Patch it with thin wire, form USB pin1 to b2b connector pins 1, 2, 3. At picture above, only yellow wire is enough.:) |
