10-15-2012, 18:33 | #1 (permalink) |
Freak Poster Join Date: Dec 2009 Location: JuankyGsm Solutions
Member: 1182337 Status: Offline Sonork: 100.1621795 Thanks Meter: 98 | Help Nokia Lumia 800 Touch Not Working and Battery With question mark.! Help with Lumia 800 Battery is signed interrogation and Touch Screen Does not Work. I need help with a scheme. For repair Please. From now very grateful. Greetings. |
07-24-2013, 13:03 | #4 (permalink) | |
Freak Poster Join Date: Aug 2009 Location: Lithuania
Member: 1099349 Status: Offline Thanks Meter: 106 | Quote:
Hi, your thread is old, but this can be helpful for others with same problem. 1. Unscrew 2 screws at top of your phone, under the sim tray and under usb port cover. 2. take out lcd and disconnect TWO Ribbon cables from Main board. 3. Connect the Wider flex connector to Mainboard and leave your second connector unplugged. or alternately you can take that smaller flex out from lcd assembly like this: 4. Reassemble your phone 5. Done, check your touchscreen. i dont know why, but disconnecting Proximity/Light sensors Flex helped for me. you know what will u lose by this. but its small sacrifice, at least youl get your TS working. press thanks if its helped for you. | |
