help please with dead 7610 hello guys, happy eid and happy new year i have dead 7610, i was trying to flash the phone on jaf also on HWK, i'll post the 2 logs maybe somebody could help me where to look for solution, if it's hardware or software either. HWK log: 1st Boot Ok, WD2, UPP: 1081 Fl0: 0x00000000-0x00FFFFFF,00000001, Fl2: 0x04000000-0x047FFFFF,00EC2250,Sam K8S6415ETB Algorithm: u_intel.fia, Ver: 4.57.0 Alg Boot Error: 2 Error Data1: 00000000: 9F 04 04 00 00 00 01 00 00 00 00 00 00 00 02 00 ................ 00000010: 00 01 00 00 00 00 00 00 00 04 EC 00 50 22 00 00 ............P".. 00000020: 21 01 00 00 06 00 00 01 00 00 00 00 00 00 00 00 !............... 00000030: 00 01 00 02 00 03 00 04 00 05 00 06 00 07 00 4C ...............L Error Data2: 00000000: D3 72 00 01 00 00 00 00 00 00 00 02 00 00 01 00 .r.............. 00000010: 00 00 00 00 00 00 04 EC 00 50 22 00 00 21 01 00 .........P"..!.. 00000020: 00 06 00 00 01 00 00 00 00 00 00 00 00 00 01 00 ................ 00000030: 02 00 03 00 04 00 05 00 06 00 07 00 4C D3 72 00 ............L.r. Before taking screenshot, expand this window ! Process Failed, Repowering Mobile Jaf log: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE605220.C1 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51PE605220.12 CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Hebrew,Arabic (Hebrew) Backing up PM Field 208 as RPL... Setting local mode... Failed! Aborting! Failed to backup imei... MCU: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE605220.C1 Booting phone... MCU ID: 0x1081 BOOT file: C:\Program Files\ODEON\JAF\Flash\w3_2nd.fia Loader version: 04.40.00 -> Revision: 0007 Boot size is 0x10A8 Boot is ready... FLASH ID0: 00000100 -> NOT USED Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 0 FLASH ID1: 00000100 -> NOT USED Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 FLASH ID2: EC005022 -> ST Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00000100 -> NOT USED Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: 00 00 01 00 02 00 03 00 04 00 05 00 06 00 07 00 Flash ID is 0x00010000 Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_amd.fia Loader version: 04.40.00 -> Revision: 0007 Loader size is 0x7EA8; Loader chk: 54 Loader is ready... P-key nokia module version 01.00 MSID: 84EF56B5C54CE680524794B849 MSID decoded: 3E4EBAF7001A2C91A9000000 FAID: 1FADD375F7C8155F7B4F4CA9 Operation took 0 minutes 25 seconds... Erasing... Found 4 interval(s) to erase Erasing area: 00000000 - 0000FFFF... Erasing area: 00010000 - 00FFFFFF... Erasing area: 02000000 - 0287FFFF... Erasing area: 02FC0000 - 02FEFFFF... Operation took 0 minutes 3 seconds... Writing... Error cmd: 14! Addr: 00000000 thanks in advanced |
sir i visited the link u sent, i read it all, i didn't found same problem, please if any one know anything or have any solution let me know |
REBALL UPPER FLASH UR PROBLEM WILL BE SOLVE. |
sir what u mean by reball, second i know that there is one flash , so which upper flash u mean too.... thank u |
still need your help please |
i try to reheat the i try to reheat the ram and the flash also, i'll post the new logs also : jaf: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE605220.C1 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51PE605220.12 CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Hebrew,Arabic (Hebrew) Backing up PM Field 208 as RPL... Setting local mode... Failed! Aborting! Failed to backup imei... MCU: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE605220.C1 Booting phone... MCU ID: 0x1081 BOOT file: C:\Program Files\ODEON\JAF\Flash\w3_2nd.fia Loader version: 04.40.00 -> Revision: 0007 Boot size is 0x10A8 Boot is ready... Error in CHK... Error Loading loader! Hwk: 1st Boot Ok, WD2, UPP: 1081 2nd Boot Error: 4 Platform: 6, Error Data: B3 72 72 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Process Failed, Repowering Mobile |
1st Boot Ok, WD2, UPP: 1081 2nd Boot Error: 4 u must change ic ram!!!!!!! 1st Boot Ok, WD2, UPP: 1081 Fl0: 0x00000000-0x00FFFFFF,00000001, this ic flash uknow u must change this ic!!!!!! Fl2: 0x04000000-0x047FFFFF,00EC2250,Sam K8S6415ETB |
rehot flash ic and ram and flash again |
betar change flash ic |
sir try to reheat upp i have already incounter that kind of problem.. post the result.. |
