12-29-2002, 17:57 | #1 (permalink) |
No Life Poster Join Date: Jun 2002 Location: Iran Age: 47
Member: 12724 Status: Offline Thanks Meter: 30 | HElp to remove the glue. I was wondering to know how can I remove the glue used beside and under some BGA IC's such as CCONT in 8210? Is there any special Liquid? I tried it with Hotair and the phone!! pls help |
02-06-2003, 09:41 | #4 (permalink) | |
Member: 12724 Status: Offline Thanks Meter: 30 | Quote:
03-17-2003, 19:47 | #5 (permalink) |
Junior Member Join Date: Sep 2002 Location: Malaysia Age: 42
Member: 15979 Status: Offline Thanks Meter: 0 | Remove CPU Easily.....Interesting??...Check it out!! For those who confuse about removing your CPU ic, Here is a new way to do it easily.... Let me introduce"GLUE REMOVER". This GLUE REMOVER is a water epoxy that can be remove glue at cpu or ccont and any ic stick with glue. The method is easy. You just need a ****er station,cutter and GLUE REMOVER. You just put a few GLUE REMOVER surrounding the ic that you want to remove. Then ,wait about five minute and use your ****er to **** it about one minute, after that use your cutter to pull it up slowly.Finally, glue will automatically stick at ic. I can guarantee the glue will stick at ic and it wouldn't stick at the board. So that you are non need clean the glue at the board. This method is faster and easier. It only sell US$15.00 per bottle weight 50ml. Courier Charges are depends on destination. For more information, Please not hesistate to mail it at [email protected] or [email protected] |
03-18-2003, 19:29 | #6 (permalink) |
Freak Poster Join Date: Mar 2003 Location: MNE Age: 43
Member: 23848 Status: Offline Thanks Meter: 13 | Dear WesleyCHC,interresting thing called GLUE REMOVER you have!!!I would like to see its effect on a specific PCB!!!!Frankly-I don`t belive it!!!!!!!!! First-there are several types of glue,one remover cannot effect on every glue!!!!!! Second-glues used on PCB are mainly epoxy consisted of two or more chemical components and the process of hardening is ireversible(means that,once mixed, those chemicals cannot be disolved into their components) Third-If you,somehow,find a desolver for the glue I`m sure that it will desolve the PCB!!! I have consulted various chemists that made many experiments and tests on different glues and results were the same-no results!!!!!!!!! The only way of removing the glued BGA parts,for now,is slow and step-by-step heating with BGA flux.After that you must clean the PCB from the rest of the glue and pray that you didn`t damage anything!!!!!(I would like that someone will find the substance that will remove the glue and show me that I`m wrong) So,call me a Belive-not-pal,but i don`t belive it,pal!!!! Show me that I`m wrong!!! |
03-18-2003, 21:27 | #7 (permalink) |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | @Rhamses i "belive" WesleyCHC @ he keep on sell some item that he does not know it, and keep on advertisement spam for it ! http://forum.gsmhosting.com/vbb/show...205#post330205 as he said :"use your ****er to **** it about one minute" ! hehehehe,, just one minute enough ? Willy |
03-19-2003, 05:48 | #8 (permalink) |
Member: 15979 Status: Offline Thanks Meter: 0 | I don't want to argue with you anymore willy. Believe it or not, it's up to you....... @Rhamses I just can let you know, it will not effect on PCB. as you said u use flux to slowly remove the CPU, your way aslo can do it, if you are pro...but for newbie is very dangerous. But i think for willy is easy, he said using ****er only when adjust the right temp, then he's more pro. but for newbie is very dangerous too.. |
03-19-2003, 17:03 | #9 (permalink) |
Member: 23848 Status: Offline Thanks Meter: 13 | @ WesleyCHC Pro or non-Pro,removing glued BGA parts is a job that requires time and patience. For now I will continue to use my amateur way of removing glued parts untill a Pro shows me a different,better way!!! Geetings!!!!!! |
04-02-2003, 07:08 | #10 (permalink) |
Junior Member Join Date: Apr 2003
Member: 25798 Status: Offline Thanks Meter: 0 | Hey WesleyCHC. Which part in malaysia do you live? I live in kuala lumpur. If u really have that things, then i should give it a try. Can u reduce the price some more ? U can mail me at [email protected] TQ |
04-02-2003, 22:13 | #11 (permalink) |
Insane Poster Join Date: Mar 2003 Location: London Age: 41
Member: 23790 Status: Offline Thanks Meter: 0 | @WesleyCHC man, i cant believe you coming back again and again...why are you advertising your product here...if you know its wrong section, dont annoy people...you already letting yourself down...if i were you id stand back and proof that im not giving **** to people...but if i had crap product i'd shut up and never come back at least to this section... dont get me wrong...nothing personal...its what you are selling... |
02-23-2004, 12:48 | #12 (permalink) |
Freak Poster Join Date: May 2002 Location: dubai
Member: 11945 Status: Offline Thanks Meter: 76 | ppl look here plz. http://forum.gsmhosting.com/vbb/show...t=glue+remover |
What do you use to remove transparent glue on IC? | MWP | DreamBox | 31 | 03-30-2008 13:45 |
N80 Dead By Removing The Glue | hardwork1 | Nokia Base Band 5 ( BB-5 ) | 0 | 11-18-2007 23:49 |
N80 dead after trying to remove the hard glue | samuelscu | Nokia Hardware & Hardware Repair | 16 | 10-08-2007 18:35 |
SF65: How to remove the GPRS icon on the display? | gianlukko | NON Siemens Brand (ODM Phones) | 2 | 12-24-2005 18:42 |
