02-16-2004, 19:05 | #1 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Everywere Age: 46
Member: 18057 Status: Offline Thanks Meter: 64 | 1100 Flash Ok not Powered On. 1100 Flashing ok / But, will use Power On/Off Error. in griffin. any idea about this prob... hareware/software. or any solution then pls..... give me. thanx [email protected] b.r. akki |
03-16-2005, 21:58 | #3 (permalink) |
Cheater -Don't Deal with him- Join Date: Mar 2004 Location: GERMANY Age: 42
Member: 60523 Status: Offline Thanks Meter: 9 | try to make eras flash or use any file eraser then flash the phone last version rh18_05.600 last write pm value it will be ok B.R ROBISH |
03-17-2005, 00:15 | #5 (permalink) | |
No Life Poster Join Date: Apr 2003 Location: Bled lekhla
Member: 27291 Status: Offline Thanks Meter: 81 | Quote:
change the trade please !!! ashamed | |
03-17-2005, 19:14 | #9 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: Bandung - West Java, Indonesia Age: 43
Member: 71273 Status: Offline Thanks Meter: 14 | Quote:
there is no switch on off in 1100 (RH-18), please do not give bad suggestion to this forum, it can make someone "goes away" from this forum. @akhsay try to reflash with UFS-3, i have the same problem flashing with griffin can not power on, but after i was flashed with UFS it showed "UNKNOWN FLASH MANUFACTURE", so i was reball the flash ic and erasing the flash, flashing again, upload the PM, the phone can switch on. but i want to ask, does the phone can go to the test mode after you flashing with griffin?? because in my experience to read the IMEI with griffin, the phone should goes to test mode then the IMEI will shown. if yes and the IMEI ????????? the problem cause from UEM, becareful to change the UEM in 1100, it glued brother ...!!! Best Regards Unggul | |
03-18-2005, 14:21 | #10 (permalink) | ||
Member: 60523 Status: Offline Thanks Meter: 9 | Quote:
read good it is software problem and no need to change uem try to remake the steps i mentioned before B.R ROBISH | ||
03-19-2005, 14:50 | #15 (permalink) | |
No Life Poster Join Date: Jan 2005 Location: NEW DELHI, INDIA Age: 50
Member: 111665 Status: Offline Sonork: 104250 Thanks Meter: 180 | Quote:
sharp gx29 flash ok not power on | Formingus | Sharp | 1 | 02-20-2007 12:26 |
Platiji Help me :-( GX15 flash ok, not power on ?????? | Dynamitor | Sharp | 0 | 04-16-2006 13:51 |
2650 flash ok not power on | kardelen gsm | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 01-26-2006 16:56 |
1100 Flash Ok not Powered On. | akshay | Nokia Hardware & Hardware Repair | 9 | 08-18-2005 21:46 |
8310 flash ok,not power on!!! | kostenlose | Nokia Hardware & Hardware Repair | 10 | 07-25-2004 04:58 |
